The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
eldarion
Regarding Tesla's patents, I have been looking into them for a little while, but in relation to the MAGVID, not the TPU--these two devices seem to operate on nearly the same principles.
I am pretty sure that whoever interpreted the MAGVID text got the coil diagram wrong!  I tried it as depicted and no rotating field was set up--it would not even spin a bar magnet.  The correct diagram would seem to be exactly like the TPU and Tesla's patent (and also his Egg of Columbus experiment--see attached)--this altered depiction matches the text perfectly.
I am currently attempting to build the device set forth, but with one difference--Tesla designed that device to run at very low frequencies, around 40-60Hz or so.  If you try to feed higher frequencies into the device, that iron-wire core will start to absorb all the input energy.  I will try two different setups, one air-core (which I don't think will work because the independent fields may not mix properly to set up a rotating field in the middle of the device) and one with a large HF powdered iron core.  Alll will be four-coil, two-phase driven.  After the rotating field is set up properly, I have a bunch of experiments to run on that field, which I'll post here after I do them. :)
Hopefully this way we can clear up a bunch of the hype surrounding fast rotating magnetic fields once and for all! ;D
Eldarion
EDIT: The forum would not let me attach the PDF file here, so here is a link to it: http://www.overunity.com/index.php?action=tpmod;dl=item31
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
aleks
Quote from: eldarion on April 11, 2008, 01:45:00 PMHopefully this way we can clear up a bunch of the hype surrounding fast rotating magnetic fields once and for all! ;D
Well, I hope so :) Thanks for your devotion to this topic in general, it's always interesting to see new findings along these lines!
giantkiller
ALL THREE FREQUENCIES ARE FED INTO A SINGLE WIRE SIMULTANEOUSLY. You will learn why below.
3. How to feed the necessary frequencies to the appropriate coils, and do so using feedback from the output.
This hit me like a thunderbolt. Since the output is pulsed DC, at three frequencies, all that is required to "tap" the output is a blocking diode, with a resistor or thermistor to limit current to the control coils. This IS FED TO A THREE WAY CROSSOVER, which splits one signal into three, and routes said signals to the appropriate control coil inputs!!!!!!!!!!
I THOUGHT THAT STUPID "CONTROL" IN THE CENTER OF THE 17" TPU LOOKED FAMILIAR!
The oscillator circuits feed three mosfets, each connected by matched resistors to positive, fed through diodes into a single wire into the crossover. ALL TPU CIRCUIT GROUNDS ARE SHARED.
SM flips 2 switches on the SM17 stating freq 1, freq 2.
I got to know.
--giantkiller.
hydrocontrol
Quote from: aleks on April 10, 2008, 04:13:56 AM
Why not just take a 3-phase motor and replace its rotor with a coil? Guess it won't work, because this overunity FX is not about rotating mag field. Rotating mag field may cause ether inertia effects to manifest, but do you really think it produces electric potential higher than what you have on your coils?
When I read this something just clicked about the (mythical Pierce Arrow) car that Tesla had a 'specially' built electric motor. What if the motor coils were actually wound like a TPU and the 'control' box of vacuum tubes generated the frequencies and timing. This would be equivalent to the spinning compass inside the TPU showing a magnetic vortex but on a much larger scale. Just something to think about.
giantkiller
Quote from: sparks on April 10, 2008, 09:54:56 PM
   Instead of winding three control windings covering different portions of the tpu od would it work out better to have three windings wound around the whole circumference that are next to each other.  Route the feed from the pass filter so that there is a directional shift of energy with each set of turns representing a pole.
Could be quickly run with 3 lead ribbon cable.
--giantkiller.
