HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
Cap-Z-ro
Good job by all involved - a fine example of cooperation and teamwork.
I have been interested in the operation of this device and its potential for a number of years...due to my lack of formal backgrounding, I try to stay out of the way in technical discussions, and will continue watching and learning until I have something helpful to contribute.
@ Jack...much thanks to you for helping the cause.
Did you get a chance to examine the switch box that the TPU was wired to ?
I am concerned that the depth of the average box together with extra wide box used in the demonstration would provide space for the batteries some speculated were hidden inside the unit.
Anyone familiar with electrical installation can see in the above pics, that much narrower switch boxes are normally used to house common wall sockets.
It appears there is something besides the plug socket in the switch box...could it have been an DC to AC converter ?
Regards...
EMdevices
I like many others, at one time believed this was possibly fake and used batteries, but it is NOT SO.
Just read once again the report from Dr. Schinzinger:Ã,  Ã, What does that tell you about it's output resistanceÃ,  (internal source resistance)?Ã,  It tells me it is very small, less than one ohm, since the current goes from one amp to two amps and the voltage practically stays the sameÃ,  (137 Volts) so it's within the round off error on the ampmeter display.Ã,  Note, the output is DC, makes you think doesn't it?
Also note that he shorted the large tpu across a 50 amp fuse, with only a small flicker on the connected lightbulbs.Ã,  Ã, What does that tell you?Ã,  This tells me this thing has freeking lots of power potential with a VERY LOW INTERNAL RESISTANCE.Ã,  If you will, it's the same for a simple coil of wire, THE COLLECTOR, that SM has been refering to, and a moving magnetic field that induces "electron flow of high order".
No friends, this is not a battery , but it's what SM said to us in his letters, read them carefully, they're packed with info, and the descerning mind will draw valuable info from them.
Here's the report once again:
Roland Schinzinger, PhD.
29 Gilman St. Irvine, CA 92715-2703, Phone & FAX: (714) 786-7691
Second report on Energy Device
At the request of Steven Mark I agreed to thoroughly test his invention of an energy device Ã,“toroidÃ,” at my laboratory at the UCI campus.
With me was John Sanchez who will act as an observer and Mr. Mark who will operate his device for the tests.
The device is reported to develop measurable amounts of electric power beyond any known battery or storage device. In fact the inventor claims that his device will create electric power indefinitely as long as it is permitted to cool at intervals.
Mr. Mark arrived promptly at 8:30 AM and wasted no time in permitting my examination of two units.
The first unit was roughly shaped like a large donut. It measured approximately 4.72Ã,” across with an inside diameter hole of 3Ã,” making a core width approximately 1Ã,” thick
The unit was exactly 2Ã,” tall, resembling a Ã,“ToroidÃ,”. I did not measure the weight however the unit was extremely light when held in the hand.
Mr. Mark connected the unit directly to a 100 watt 120 volt incandescent light bulb and caused the unit to operate. It did in fact illuminate the incandescent bulb quite brightly. I measured the voltage at 137 volts D.C. exactly, (ObS). See note*
I then measured the current flowing through the wires to the bulb at a steady one-ampere, (ObS).
We noted the time at 9:06 AM.,(ObS).
We next measured the light output from the bulb with a luminescence meter and noted that it read2.5, (ObS). Next we measured a similar incandescent bulb placed in a socket powered from the main 120 volt (as measured) AC power provided to the laboratory. It measured 2.4 on the luminescence meter. This can probably be accounted for because the voltage as measured from the Toroid device is 137 volts and therefore 12 volts greater, generating a slight increase in light output over the incandescent light powered by the laboratory main power supply system.
The toroid device did indeed provide the standard voltage and current necessary to provide electric lighting for a 120-volt circuit.
The inventor then asked us for another bulb, which we provided him and he set about connecting the second bulb along with the first.
The second bulb was connected in parallel to the first and did indeed light just as brightly as the first.
I measured 137 volts now across the output just as before although the load had doubled and the impedance halved (ObS).
I measured the current flowing to the two bulbs at just less then 2-amperes, (ObS).
The inventor stated that the unit would provide the two amperes at 137 volts for several hours, if not indefinitely. We were cautioned that the unit while in operation would generate heat leading to self-destruction if not shut down and permitted to cool. He claimed that after cooling the unit could be restarted and used again over and over.
We permitted the first unit to remain in operation and provide power for the two incandescent bulbs while we turned our attention to the second larger unit the inventor brought with him for testing.
The second unit was again toroid shaped with a large hole in the center. It was approximately 15Ã,” at the outside and 13 Ã,“ inside with a core thickness of approximately 1Ã,”.Ã,  The unit was 4Ã,” tall. The unit was not measured in weight but could be easily lifted with one hand, (ObS).
The inventor started the second larger unit in operation and cautioned myself and Mr. Sanchez not to touch the output leads from the device as they were at lethal potential. The time was 9:39 AM.
The inventor measured the output leads and told us there was 600 volts potential at several amperes.
He connected the unit to five 120 volt 100 watt incandescent light bulbs as provided by myself. The larger second unit did indeed brightly light the five incandescent bulbs brightly. These bulbs were wired in series.
I measured the current through the wire connected to the 5-bulbs at 1.1 ampere, (ObS). I measured the voltage at 614 volts D.C., (ObS).
The inventor then connected another five 120 volt light bulbs along with the first five making a total of ten 120 volt, 100 watt incandescent light bulbs lighting at equal intensity.
I measured the light output with a luminescence meter at 2.43 each light bulb, (ObS). I did not measure the current but calculated it to be 2 amperes at 614 volts.
I asked the inventor if this was the limit of the unit and he replied, Ã,“by no way.Ã,”
He provided a quick blow fuse rated at 50 amperes.
With two large electrical clamps and wiring, he shorted the fuse across the output terminals of the toroid and destroyed the fuse, (ObS). There was only a slight flickering of the ten incandescent bulbs as observed although there was a tremendous discharge of sparks from the output terminals of the toroid unit.
The inventor then gave me the fuse for examination. It was warm to the touch and smelled acrid, (ObS). It was a large 240 volt AC air conditioner disconnect fuse and designed for severe service duty, (OsS).
The inventorÃ,’s claim that the large toroid output terminals were at lethal potential was no longer in question.
The time was 11:20 AM when the inventor removed the small toroid unit from operation because of heat build up.
I examined the small toroid unit and it was indeed quite hot to the touch.
The unit had been in steady operation for exactly two hours and fourteen minutes.Ã,  Noted: 2-hours and 14 minutes, (ObS).
The load of 2- amperes at 137-volts did not change through the test period.
I can personally state that I do not know of any battery or storage device of this size or weight with this capability.
The time was 12:47 when the inventor removed the large toroid device from operation.
It had been in constant operation for three hours and eight minutes.
Noted: 3-hours and 8 minutes, (ObS).
The load of 10-amperes and the voltage of 614 volts did not change throughout the test with the exception that the voltage did began to fluctuate at 12:03 and began a slight decline to 598 volts by the end of the test. This could be due to heating of the unit while in operation.
I cannot determine how many hours the toriod units could potentially operate because of our limited time available for testing.
I can however state with relative certainty I believe the tests show great potential for this Toroid technology.
December 12, 1995Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Roland Schinzinger
*note:Ã,  (ObS)Ã,  Ã,“also observed by John SanchezÃ,”.
P.S.Ã,  I drew this collector diagram to illustrate the output circuitry of the TPU based on these clues.Ã,  Yes there are dual stacks as seen in the spool TPU, and control coils as well, but this is just about the collector coil as SM called it.  With this model we will have some "hash" as SM said, but it's mainly DC, just like he said in the videos.
Jack ,
can you give us a few more names, who were involved in all
of this at this time you were around this ?
Who are the other persons in all the videos ?
Maybe if we can reach them and ask them also questions
we will still get more informations by some other persons
who might have played still more with the devices than you yourself.
Many thanks.
jdurban
Regarding the other players surrounding the technology... There were no other people around outside of those mentioned. Most all of the inner circle were investors, Steven's attorney, and periodic visits from Spheric management. No one had unsupervised time with the devices including myself.
The video by the way, is a direct cut from the hi-8 master. I just dubbed the DVD I made years ago as a backup in case someone broke in and found it.
Getting back to prior statements...When I look at the output chokes and large polycarb caps I can't help but think that these are used as a means of isolating the load from the output. This theory would prove true if one were to discover that the output was feeding the choke/cap pairs in series. I cannot fathom why these would act as hash filters since the output is H.F. to begin with. In other words I only use chokes like these to mitigate noise in exotic power supply designs utilizing switching type regulators. The TPU is already producing H.F. so why filter it? The only argument I can see in opposition would be the I.R. drop across the chokes causing moderate to high localized heating. A slight discoloration of the choke windings would occur during operation perhaps even localized visible heat vapor. Another hint to consider is the capacitor chemistry selection. Why such an exotic cap? The polycarbonate capacitor exhibits very low ESR providing the purest or most ideal filtering characteristics especially in an application using higher voltages.
Do remember that Steven could not run inductive loads for quite a while. The youtube video that shows Steven running inductive loads was indicative of his finding a fix for the problem. The video quality however is so bad that it is very difficult to spot and obvious hardware mods made to the device.
Windows has detected a mouse movement and will now reboot.
jdurban
I just read references to the output being R.F. I disagree. I believe the output was around 6khz as Steven stated. I have designed a lot of transceivers and R.F. just doesn't fit this form factor at all. R.F. is grossly inefficient under ideal conditions. Seeing how imprecisely wound the coils were I find it difficult to see R.F. at play here. I would be more open to considering that the quadrature orientation of the coils may act in some way like a phase locked loop. In other words consider that during startup an unlocked frequency or carrier if you will wonders around a bit then reaches a frequency that causes the secondary to resonate at some fundamental or harmonic frequency likely a multiple of the Schumann Cavity.
This may sound like a long shot but the more I ponder all the possibilities I keep coming back to a tuned resonant tank within a secondary tank.
