The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
pauldude000
@art
I had the notion also that maybe I was not using near enough inductance for the signal... Maybe there was practically no field present to fight. I have since then found a false negative. I have a matching pair of metallic crystaline magnets, which I chose for this test. JUST TOO BAD THE ARE NOT MAGNETIZED ON THE FACES!!!! GRRRRR! Guess who didn't bother to check... <<<---------- ME
I do not have a clue how they are oriented, what a monumental waste of time.
As to your other question, I was not using dual trace on the signal, just a single. However, I sincerely doubt false triggering of the scope, as this  happens only within a very narrow range of frequencies, which varies as to different coils. This tells me it is an aspect of the signal read, and not a false positive. What do you think. I could be wrong.
Paul
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
@art
Check with a small bar. North end always points to south.
Rewound another. It is definitely NOT acting like a diode.............. However, either I am crazy, or my scope is crazy, or I am at a complete loss to explain just what IS happening in these things. The field has gone nuts.
It is doing things I never thought possible, never even though ABOUT.
I checked my circuit output, suspecting a damaged 555 circuit, found a blown transistor. Replaced, best square waves you ever saw. Put the signal through a diode to prevent backfiring (tired of fixing 555 circuits.) Excellant signal!
Put it through the magcoil, and the field is even MORE screwy. Adjust the frequency, and I watch the screwyest effects I really am at a loss to understand. Might have to post some pics, just for freakout value.
No, I am not just getting "sines"... (I dont really know WHAT to call them.)
Whether I can get a TPU to work or not, I am going to HAVE to investigate this further, later.
Paul Andrulis
pauldude000
@art
I wonder. We have been taught to remove all traces of variant signal, to ignore aberrations, to (in essence) ignore the obvious. I remember reading one of Tesla's papers in which he stated that multiple signals can travel in the same conductor, both separate and independent of each other. WE know that is possible, just examine how the transmission line of an antenna works........
Ask yourself what I am now having to ask myself. "What If".
By the way, I have now discovered that you can pull energy out of a magnet (side product of recent experiment.) I have also learned that to recharge a 9v battery from said, it might require a roomfull of them to do it. :D Possible, but not really practical. A magnet with a fine wire (30 ga) coil wrapped around it was putting out a steady 20mv peak to peak AC, measured at 5mv/div at 50ns. (yes I aligned my DC line to center of scope)  I also found out that it can jump to about 1v pp in a thunderstorm. WOO-HOO!
Maybe I should run it through a full wave... :D I could power my house tomorrow!
Paul Andrulis
aleks
Quote from: pauldude000 on April 17, 2008, 03:19:03 AM
You won't achieve that with a single rectifier stage. Since oscillations are random you need a more involved arrangement. I think you will need a rectifier ladder of some kind so that you can cover a wide range of signal amplitudes - it is like analog-to-digital converter, but with each bit stage outputting power so when you have a large signal this rectifier ladder should "light" all lower power rectifier stages. Each stage should probably be low-passed by means of a small choke or RC (RC should be simpler).
pauldude000
@aleks
Answer me a simple question, and I will call you "King of the Power Grid" (you quite literally would be), under the terms that you must accept the basic premise as possible first. I am not interested in why "it cant be possible".
Question : How do you separate for use 100 or more individual frequencies of the same or close frequency which just happen to co-exist side by side, separate and individual of each other, yet traveling/co-existing in the same conductor????
I only can only guess to turn them into DC and hopefully they mix. Anything better?
I just realized what I witnessed, though my brain is already making up excuses why it "cannot be so". How such could be, without summing and inherent blending is beyond my knowledge, or my current ability to envision such. Durn it, it CANT be so, yet............
Paul Andrulis
