Liberty
Quote from: z_p_e on June 24, 2006, 06:43:04 PM
Exactly!
Not a mass of circuitry...again probably implying that there is circuitry, just not complicated circuitry.
For those not "in the know", before any real progress can be made with this device, the question of whether a battery is needed for its operation is fundamental. This is fundamental to successfully duplicating the device, and I am convinced there is one.
Liberty, you mentioned the 2nd video, it sounds like one that I have not seen. Could you please indicate what the file name is for this video clip and where it can be downloaded?
Thanks,
Darren
I'm not sure where the videos are all at, but here are some videos and some pictures.  http://www.overunity.com/stevenmark/
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
gn0stik
I have no idea how you can make any of that out from that picture. It's totally blurry. I watched the video, and it doesn't appear to have any wires running into the corner of the magnet, he Just sets the magnet on there and removes it, to demonstrate it spinning up and down.
tishatang
I posted earlier about Moray needing a ground.  Another article says otherwise.
Link:       http://amasci.com/freenrg/fnrg.html
Which leads to this link:
http://web.archive.org/*/http://www.newphys.se/elektromagnum/physics/KeelyNet/energy/moray1.asc
" What sort  of an apparatus is  Moray's  Radiant  Energy  Device?
    Briefly, it would  appear to be similar to a radio receiving  set  of
    power proportions.
         It is  composed  of  two  coils  of  wire, or inductancies.   It
    contains several condensers, or capacitors, of different sizes.
         There is  a  detector  tube,   or   electronic  valve,  and  two
    oscillator tubes.  Added to this is a "bar of silver  and  a  bar  of
    copper", a starting  device,  and a step down electrical transformer,
    reported to be 1000-to-1, primary to secondary.
         All of this is enclosed in a box  measuring about 30 inches long
    by 16 inches  wide  by  16 inches high.  It weighs about  50  pounds.
    There are no   moving  parts.  Moray  says  there  are  no  dangerous
    radiations surrounding the box when it is in operation.
         Many persons have looked inside  the  box.    Several  have made
    more than a  cursory  examination of its contents -  except  for  the
    detector tube!
         The inductances  are about eight and 10 inches in diameter. They
    are composed of several layers of wire.   The diameter of the wire is
    much smaller than necessary to carry  anything  like  50 kilowatts of
    ordinary commercial electricity.
         Probably, there is a direct relationship between the size of the
    wire and the number of turns of it on each coil.  Further,  it can be
    assumed the distance  separating  the two coils is important, as well
    as the direction in which the coils are wound.
         Moray is silent as to the materials  used  in  his capacitors or
    condensers.   Neither does he tell their capacities.    They  vary in
    size but this is not indicative of capacity!
         If one  part  of  the apparatus is more important than another I
    would conclude it is the tubes or  valves.    Moray will not say much
    about these.   He  admits they do not contain an electrically  heated
    filament whose radiations  provide  the means of carrying currents to
    different parts of the tube and which produce the valve action.
                                    Page 5
         How, then,  is this valve action produced?   Moray does not say.
    I have learned,  from  other  sources,   of   Moray's   purchase   of
    radioactive materials.
         I have  been  informed  by  one  source  that Moray  uses  these
    radioactivities as the "carrying-currents" within his tubes.  Exactly
    what the radioactive materials may be, I have not learned as yet.
         Some say  it  is  a uranium compound; others deny this.  What is
    more, we do not know whether the detector  tube  and  the oscillators
    use the same materials.
         Being cold tubes, it can be assumed they are not  vacuum  tubes.
    However, Moray does  have  vacuum  pumps in his laboratory. The tubes
    may be filled with gas.  But if they are filled with a gas, what gas?
         These tubes, especially the  detector,  seem  to  be the weakest
    links in the chain of parts in the Moray system.  By  far the greater
    number of times  the  demonstration  apparatus has stopped because of
    troubles, it appeared the trouble lay in the detector tube.
         Moray does  not  allow  anyone   to  see  the  detector  tube  -
    apparently the big secret of the device lies there!
         At the same time, the least understood of the device's mysteries
    is the function of the bar of silver and the bar of  copper  set side
    by side.
         Are they "true" copper and silver?  Or are they alloys -possibly
    treated with the  very radiant energy they may help to produce?  Have
    they been transmuted in some way?   Are they only decoys?  Are they a
    special type of   air   condenser?    Are   their  lengths,   widths,
    thicknesses, as well  as  their  distance  apart, important?   All of
    these questions, and many, many more,  flood  into  one's  mind - and
    remain unanswered!
         Early in his experiments Mr. Moray used both an  antenna  and  a
    ground connection.   He  no longer uses either.   This eliminates the
    possibility that he taps either current  from  power  lines  or  from
    radio transmitters.  "
Haven't read the rest of this thread, but seems Moray had more in common with Mark device than I realized.
Tishatang
mark australia
Dear Lindsey..could you find out for me what motor this was ..I am looking at building a hybrid. I know its of the topic but would help me.
I found a wonderful 2-stroke gasoline engine that would put out 25 hp on one gallon for 3.5 hours.
Kind regards
Mark
HMM
Who is performing the experiment in this picture?
