Localjoe
@nightlife
Thanks for the offer ive seen it and i think its already being dicussed here on antother thread.  But if anyone hasent seen it its a cool little circuit that guy shows  ;)
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
nightlife
Localjoe, thanks for letting me know it has already been discussed. It saves me the time and money trying to replicate it.
Localjoe
Localjoe
@jim
I Checked that site, pretty cool.   ;) I Recently did some test in the ground with the cells i made during winter and wanted to share the results. As well the X factor held tru the readings in the ground vs the readings in the water were higher.. Something is there but it's still an x factor.   hopefully not an ac motor somewhere in the house ;)   As well what if we made a small realy i mean really small for the top of this thing.  Say 30 gauge mag wire quarter inch or less diameter, real small contact.. i think .7 v should be enough to drive that.  Before i had wanted to use the natural action of the existing primary winds as a relay and just make contact peices but i think this smaller coil relay method might suite our small voltage and current req.
        Joe
electricme
@ all,
Back again, yes Joe, I have some really small dia insulated cu wire, I was thinking also to put graverty to use with it to.
Im thinking on the lines of using a vertical setup, winding some turns on a hollow former, then hang a steel armature in the middle of it and see what happens when it is connected to the earth rod setup. Connect a diode in series with the windings and see what happens here too.
The thing is (I think) just to get some type of mechanical action, no matter how small, then proceed further.
Later on work out some form of switching do put on it.
jim
People who succeed with the impossible are mocked by those who say it cannot be done.
