The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
otto
Hello all,
@AM
I have to be honest: I promised a nice man here in the forum to build my tube oscillators.....
35 years ago I learned everything about tubes. I was really good. Tube radios, tube TVs. In the times of tubes I learned in school how to repair tube TVs and in the same time had a lot of TVs to repair!! And I earned a good money as a very joung guy.Then came the time with transistors, ICs.......and as it happens, I forgot everything about tubes....
How I see the development of a TPU:
- SM was a TV repair man, he knew about the TV story and wanted to know what happened when the TV got out of frequencies.
- I think he was playing around with a deflection coil
- as a TV had tubes, SM used them also in his work
- the voltage on tubes plates is say 300V more or less
- with such signals he was pulsing his TPU and got it work
- later he had to use SS because tubes are a little big, ha,ha.
- with SS devices, to say MOSFETs, he had nice signals but at a low voltage level and so he had to think about how to rise the voltage of the signals - to get biiiig signals, like with tubes
- the solution is well seen: additional coil(s) sitting in the center of the TPU
In this way he got an easier acceleration of the particles, he didnt had to use a soooo high frequency to accelerate the tornado and at an unknown (?) frequency mix the tornado accelerates for itself so....
He got nice clean signals
and he got biiiig signals
This all I see with my setup.
I only need to rise a little the voltage from my power supply and then......I can again repair my equipment.
I think its enough crap from me this week.
Otto
PS: AM, maybe you know something about the AlMn alloy???
pauldude000
I have had another "Thunk" situation, and people REALLY ought to read Steve's words in the pdf CAREFULLY, but especially with an OPEN MIND, not cluttered with presuppositions. (Like I originally did.)
I was ALMOST correct before. Now I am cautious. :o
The device is ALMOST solely Tesla type tech. I think Tesla himself would have achieved this if he would have retained his lab and funding. It is based quite heavily upon what he proposed.
Steve himself stated EXACTLY how to wind the setup...... This ought to sound familiar.
"Listen, you need to make three coils or so one on top of the other. But the important thing is to wrap the control coils perpendicularly around the collector coils. There need to be three of them all the way around." <-SM
"About the collector:   It is three separate coils of multi strand copper wire laid one on top of the other, not interleaved. Three is important. You can do many things with three coils. You can run them in parallel, you can run two in series and one in parallel, or etc" <-SM
"The control wiring is vertically wound in several segments around each of the horizontal collector coils. Other control wires are wound around all of the horizontal collector coils together. Through the different control wire and coil wire arrangements you can keep complete control of the unit most of the time." <-SM (otto AND tao were each half right. I was quarter right.)
"About the collector: .....................You can run a separate frequency into each coil for better control on large power units if need be."
   BOTH the controls and the collectors are pulsed. You will remember that SM stated that we should imagine a field rotating in TWO directions at once. (Rotating around the coil, with spin. IE rotation on two axis. This is what happens with field collapse in the coils, the second rotation,  or spin, starts and is accentuated with the pulsed collectors.) Now consider a basketball. If you shoot the ball with your hand placed improperly to the side and back, it imparts a two axis spin, rotating backwards and to the side at the same time. Magnetic fields out of alignment try to align with each other. That is why a compass works.
The pulsed controls set up the initial field and start rotation. The pulsed collectors induce secondary spin and help control the effect. Rotation lifts the hose, spin squeezes it.
High voltage short duration pulses in the collector provide for alot of "squeeze"..... (Center toroid is a pulsed step up resonance transformer) Cap discharge through High voltage mosfets into both collectors and at least one, preferably two or more collectors.
Man, my brain is on fire, and it is LATE here, I hope I can get some sleep. I mentally feel like a rabbit being chased by a bobcat!
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
otto
Hello all,
@AM
thanks for the links.
AlMn alloy has special magnetical properties, like the alloy in the patent. I found only 1 site with a short description.
Otto
Feynman
ahura:
Triode Tubes are just like N-channel MOSFETs.   aka gate, source,drain.   They are voltage amplifiers.
http://mysite.du.edu/~etuttle/electron/elect27.htm#PowTri
http://www.angelfire.com/electronic/funwithtubes/Basics_04_Triodes.html
http://www.aikenamps.com/Equations.htm
I have several PDF books from the 1950s which are excellent as well, I can post them if you decide to make somethign with tubes.  ;)
