Feynman
You are right Stefan!  I was thinking about mechanical pencils.  There is no clay in battery graphite.  I am tempted to take a battery apart now.
@Earl
Perhaps what you say is true; personally I can't tell whether or not there is carbon in the toroids. I also can see the bolt you are talking about.
Supposing this is not carbon-fusion, what would this piece of equipment possibly be used for?  Does it have any commercial equivilents?   (GE CL04 three phase motor starters, two control boards, and ten toroids with steel fixation bolts).  I can't think of what the device in this photograph is, maybe you have some ideas of what it might be if it is not related to carbon-fusion.
@sulake
You are right, these components are both used in welding.   :D :D ;D
Also, hypothetically, the more carbon the more the power, but I think other factors will be way more important.   Factors such as discharge voltage, B-field bias, collector toroid material and proximity, etc.
original paper, professional translated to English:
http://www.nuenergy.org/pdf/electronically-activated-radioisotopic-carbon-generator.pdf
Toroids:
http://www.alphacoredirect.com/index.html?lmd=39452.612164
http://www.allelectronics.com/cgi-bin/item/TTX-7812/790950/TOROIDAL_TRANSFORMER,_7.8VAC_6.3A,_25.2VCT_2.2A_.html
http://www.cmi-ferrite.com/Products/Standard%20Cores/Large%20toroids.htm
Thoriated Tungsten:
http://www.diamondground.com/tungmaterials.html
Pure Carbon Rods:
http://www.tedpella.com/carbon_html/carbon1.htm
aleks
Quote from: Feynman on May 11, 2008, 05:17:04 PM
Sorry for unrelated comment... I knew at least two welder men who possessed "magical" abilities (namely, "out of body" life). Now after reading so much about spark gaps and OU I even think it's pretty common among welders (Tesla is among them - though his welding was happening in vacuum spark tubes mainly). This has something to do gravity. Gravity formation is about the only thing that can accelerate any "not known" body energies as gravity is believed to affect all kinds of matter. After all, "soul" can be also a gravitic force structure: a kind of mega particle with complex internal structure, a "spark". :) Body being a temple of soul does not sound like a fantasy after that...
AbbaRue
I tested some soft steel wire with a magnet today at the store.
It didn't stay magnetized so it will work for core material.
This would be the real poor mans way to go for toroidal.
Just wind steel wire into a toroid core and then wrap the copper wire coils around that.
I think that is what Tesla used to use in his days, from some of his drawings I've seen.
We have a BOC welding supplies here so I will be able to get both the tungsten and carbon rods.
Also wanted to say carbon crystalizes into diamond or graphite.
I find coal and graphite on the beach here in Sarnia,  because years ago some ships went down in
the great lakes, one was loaded with graphite slabs.  And also many coal powered steamers have sunk.
So once in a while some washes up on the beach.
But the graphite welding rods look easier to use.
Checking into isotopes I seen something interesting, if the theory of transmutation holds out
Nitrogen14 would transmute into Carbon14
Carbon14 transmutes into boron14
When boron 14 transmutes back to carbon14 it gives off beta at 20 MeV.
Carbon 14 transmutes  back to Nitrogen14 giving off beta but it has a half life of over 5000 years.
So any carbon14 we produce will be around for a while.
This is what we will get if we have arcing between the rods.
Carbon 14 seems relatively harmless so this won't be a problem,
and at 20MeV it gives off almost twice the energy that Carbon12 will.
If my understanding of this is right, this is very interesting stuff.
I'm excited about getting started experimenting.
BEP
IMHO...
The photograph offered as some kind of FE device is part of a DC motor control system. It reminds me of a stepped dynamic breaking system for elevators.
Also, I wouldn't give up on the Beta particle idea but I would drop the idea of metal cores in the toroid. If the basics are indeed to create near FTL negative particles in a magnetic field you will certainly have rotation. The most basic example is the Faraday homopolar generator. Place an toroidal coil covered chamber in a magnetic field and radiate negatively charged particles into the toroid core. Lorentz takes over.
It was good enough that the voltage generated from the rotation was used to perpetuate the heating of the betatron heater element. It should be good enough to provide DC to a load as well.
Earl
Quote from: BEP on May 11, 2008, 10:37:48 PM
IMHO...
@BEP,
not only is the photo faked, but Tesla_2006 said:
My results was get in the external toroid about 6 KW in my firsts tests and then autopowered devices at 110 VAC, 60 Hz and 220 VAC, 50 Hz , and I've published some results in a web site, but in spanish   http://econuclear.tk
which I find difficult to believe.  I would think that any beta interception or non-mechanical homopolar generator would only generate DC output, not AC.
Earl
