Magtap: harvesting electricity from a magnet!
Started by lasersaber, November 25, 2010, 10:07:23 AM
poynt99
Quote from: imhotep on November 25, 2010, 10:39:45 PM
I see a lot of experiments. Does anyone have working units of any of these experiments for sale/ fully assembled?
I'm looking for home lamps that require no electricity
Perhaps buy yourself some solar panels...but
Aren't you the famous "imhotep"? Hmm, I was under the impression you had already developed free energy?
.99
Sprocket
Quote from: Mk1 on November 25, 2010, 12:18:21 PM
@lasersaber
I am glad you joined the Leedskalnin Quest , so far i must admit you are one of the first to actually get it ...
I hope to help you as much as i can .
I have fond this video you will find interesting .
http://www.youtube.com/watch?v=LlAnEMfJRx8&feature=related
When the compass stops turning , it could be 1 of 2 things .
First the orientation of the device compared to the lay-lines , second the rotation gained too much speed for the compass .
Mark
Hi.  Have you observed the same effect yourself?  The video is slightly confusing in that you don't see (and aren't told) if the coils have just been energised, or are been energised repeatedly - in other words, how long the 'effect' is evident from the compass movement.  I like the idea of the circulating current becoming too fast for the compass to keep up.  Any Hall-effect device and a scope would show what was happening though...
IotaYodi
First off I hope everyone who celebrates thanksgiving had a nice holiday!
@Lasersaber. Just some thoughts here. The polarity I see here is just like a normal coil. Looking lengthwise down a regular coil the polarity is reversed on each side of the coil. I have always thought that magnets or magnetism was a form of gravity. A novel idea I have on the voltage is the forward inertia of the current approaching the apex of the rod. Just like a fast moving car going around a corner. The outside arc is longer than the inside arc. That it would seem would create an imbalance. Im wondering if a notch halfway through was made at 45 degrees or so at the apex,and iron or copper wire wound around the apex,if more voltage could be picked up. Im also wondering if a perfect 45 V would pick up more.
If a dry dc cell battery can hold a charge and light a bulb without a field collapse you should be able to use a pmh in some way.
Ive been looking at panel meters and wanting to build a standing unit. Where did you get your analog meter?
@Mk. Our conversation is not over. Your pendulum direction was different than someone elses version Ive seen. His was rotating around with the wheel. Yours makes more sense as its a pulse. The black hole gravity video got me to thinking about its gravitational spin. Ill relate my thoughts on this in your thread.
What I know I know!
Its what I don't know that's a problem!
WilbyInebriated
Quote from: poynt99 on November 27, 2010, 10:00:44 PM
.99
hey poynty,  maybe you should try using the 'search' function before making assumptions?
a search for "imhotep" comes up with a lot of hits, including this post from the person you are referring to... this is the user you were thinking of: **~imhotep~**
had you checked the thread(s) about his work, you would know this... http://www.overunity.com/index.php?topic=5296.msg118834#msg118834
p.s. don't forget to tell ion et al. i'm sure they will get a kick out of it... ;)
poynt99
Quote from: WilbyInebriated on November 28, 2010, 01:08:48 PM
The squiggles etc.. I forgot about those. I've checked into the guy's work enough to have forgotten about him almost entirely, except for the notion that he believes (or believed) he had or has something that provides him with free energy.
I assumed it was the same person, and I may be wrong. Folks sometimes re-register, sometimes with only a lightly different username.
You did not say so, but do you know with 100% certainty that it is not the same person?
.99
