Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
mdlarouche
For every action there is a an equal and opposite reaction!
My personal thought is that for every action there could be any number of reactions and those combined reactions are the net energy that comprises the universe. That energy does two things.
1. If uncontrolled... radiates out from its center point in all directions, or in some cases in a linear manner
2. if properly confined and directed to channel as much of the energy in a manner that allows work to be done.
We burn gasoline in an engine where it is confined and released in a manner that allows us to do work. The heat on the other hand... much of it is lost parasitically, as is vibration and sound.
The heat, the expansion of burned gasses, the vibrations, the sound are the reactions that are derived from burning a fuel and each in their own is not an equal reaction to the total energy released but when comprised as a whole they are the sum of the total energy potential from the initial action.
The key to energy sustainability lies in harnessing all the reactions in a more complete system or by lessening the energies in some reactions so that other reactions may be augmented.
dasimpson
Quote from: bolt on December 28, 2010, 11:22:45 PM
You need power to start the process and a cell which can handle at least 1kw. This rules out 95% of the shabby DIY builds made from SS scraps.
1Kw at 13.2 volts = 75 amps! Throwing caution to the wind the cell has got to manage at least 50 amps to get enough power into the engine to run it. So if you got 4 plates hanging off a coat hanger inside a cookie jar,  using Bi Carb as electrolite and pushing 3-5 amps from a flat car battery then no you havent got a chance in hell.
AND the timing changes,  4 stroke skip spark is VITAL. Inlet valve already open 2 degrees when crank TDC if you just advance ignition = BAANGGGGGGGGG! You just found out your bubbler doesnt work too  good:)
Oh and timing does matter ..a lot. Why do you think they went to all that trouble modifying it and using plastic cogs?
sorry but at the point of ignition no valve should be open and they always fire just after tdc if not then they is a chance the engine could be kicked into reverse
dasimpson
Quote from: mdlarouche on December 28, 2010, 11:11:31 PM
Timing shouldn't matter... at least when you are talking about advanced timing and that sort of thing. Advanced timing as it pertains to gasoline engines is because of it's octane rating. I don't recall the rating of gasoline in particular but hydrogen has an octane rating of 130 which is the highest of all fuels. It will not cause the common "knocking" that is associated with other fuels if they aren't manged with their timing to prevent this condition. The mechanical timing on the other hand should be set to bottom top dead center. If the engine is new and assembled that is the way it would be set... If you're assembling an engine that has been disassembled it simply means to have the piston at the top of the cylinder during the compression cycle when the valves are closed and with the rotations of the crankshaft so that the piston has just begun to move in the downward direction. This is the point where the spark plug fires... pushing the piston down and finishing off with the next... exhaust stroke
As for the issue of two stroke vs. four stroke... a two stoke needs to be lubricated by oil carried in the fuel mixture or it will seize up and except for maybe a little experimentation... it shouldn't be used long term because it will ultimately fail. You might be able to go to the extra length of using a two stroke with an oil injection system like they use in some motocross motorcycles but it would be to the detriment of still polluting the air.
As for something else I read in another thread... to clear things up a little, hydrogen does not produce any hyrocarbons but does in some circumstances produce nitrides.
i feel the main problem is with a 2 stroke is yes the oil system but also the fact the half of the fule air pixture goes out the exuast befor compresion has ethern started
dasimpson
my unit was a stainless steel reacing tank
the outside of the tank was the anode
the inside had 40 plates in total the cathode
i thoght this would work best as i wonted more hydrogen than oxygen
i feel my main problem was the wrong engine
mdlarouche
Quote from: dasimpson on December 29, 2010, 07:18:44 AM
You are correct! In the case of a two stroke engine the cylinder has ports cut out of it. I haven't worked on a two stroke in more than thirty years but if I remember correctly both ports at some point in time are open so yes you kind of get a fuel mixture that wants to go right out the exhaust.. the path of least resistance. I suppose that the weight and density of the gas mixture as compared to the HHO is why there isn't a real problem with gasoline... other than the pure inefficiency of the system!
