Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
ramset
Fellows
I think its ROMO's pic
When you post at this forum ,if your image is to large
It makes the entire page huge and we have to scroll back and forth to read!
please keep your pics at the reccomended size?
Romo if you resize those pics the page will go back to normal.
Thanks
Chet
Thanks Grandma
Slovenia
I just found a great deal on 29% ammonium hydroxide and ordered a 500 Ml container for $10 plus $10 S&H.  That's very cheap guys.
Super God
So the transducer itself has the circuit on it? Why don't we just use that and feed it with whatever voltage it needs?
Attached is my plan layout. One problem might be the crystals being exposed directly to water. If this causes the effect to disappear I'll try a wettable envelope (although I don't know what difference it will make?)
>9000
petar113507
Quote from: ramset on March 15, 2011, 09:05:24 AM
Fellows
Thanks
Chet
Currentlyy having problems editing/finding the editbutton on that post.  I'll see what I can do.  :(
==Romo
petar113507
Quote from: Super God on March 15, 2011, 04:56:12 PM
The ultrasonic pond foggers have an oscilator on them already.  Those oscilators, (for watever reason) were not made to be vibrating at the 43 KHZ that we want them to.  Currently, mine does not vibrate fast enough.
When you make them vibrate faster -- you encounter "ineffecinces" -- I would suspect that this may be the reason powerme has a 36 V input power -- so that the thing still runs or produces forceful enough oscilations.  I will see about keeping the same input transformer (24v) with a faster oscilator, and seeing if the voltage input needs to be stepped up or not.
As chance would have it, one of my room-mates father's is an electrical engineer.  I will be contacting him shortly, and he should also be able to give me his "two cents" about something that should work.
Progress will first be made by someone who posts what their "known electrical engineer" says about a circut.  Mine will contact me in a few days.  If anyone else's contacts them sooner -- please post info, so that we can each 'cross check' to see if one's methods will work or not.  (For me, double checking has been a good practice thus far)
My spark plug arrived today for the 160 CC engine.  So the fogger is the last bit that I need to get working (at the right frequencies), and then I should be able to confirm a replicated "water runner".  I have everything else on-hand, and ready.
At first, I will be testing a lead-acid battery envelopes -- and a will investigate a secondary way of sticking the crystals to some form of acrylic, or steel plates, with some kind of adhesive.
This is all the progress I can report, aside from reading into some books that powerme might have also "suggested" (at least, a book related to his tangents left behind) to read about.
Will post some of these books shortly,
==Romo
