Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
No, I haven't built anything yet.  I've been in the alternate fuel business about seven or so years now and wasted a lot of money on projects that didn't pan out, so I'm a lot more cautious now.  I do feel very good about this project.  My gut tells me this is the real deal and that's why I have spent so much time with it.  I also believe that Power1 will show us more stuff if we show him some action, activity, on his cell and I do plan to do that soon.  I got my powder yesterday and should get my ammonium hydroxide by Tuesday of next week.  I don't have my stirring sticks yet.  I've been designing my cells.  I've been utilizing some techniques Romo shared with us about a week back on contacting the higher self.  I think I am starting to see some positive results.  Thanks Romo.  Anyway, I saw the fan on the top of Power1's diagram and noticed that I hadn't heard any explanation of a fan.  There are some other components talked about though that are not shown in the diagram.  We are getting really close guys.  I think we are going to see some very positive results shortly and then Power1 will open another door for us.
Best Regards,
Slovenia
Quote from: superman9976 on March 19, 2011, 11:35:12 AM
I think the fan is for recirculating the fog and creating turbulence in the chamber.  The fog always tends to stay low cause its heavier than air.  Did you try creating fog yet?  This is what I observed.
Slovenia
The acoustic horn needs to be made out of brass and I think of fairly thin material.  The configuration of the horn needs to be just so I'm thinking also.  I also think the   bowl receivers need to be made of brass also.  Anyway, I'm thinking that the bowl needs to be able to vibrate too.  The bowl is pure speculation on my part at this juncture.  I will probably try something else first and then experiment with the brass bowls later.  There are a lot of brass bowls available from India and they are fairly inexpensive.
I may be wrong on the bowl material.
The Power To Be
Quote from: Slovenia on March 19, 2011, 02:23:38 PM
There are many fascinating things you can do with Brass in acoustic cavitation!. The sky is not the limit, water has many many phases. For the water fuel project, simple atomizing ultrasonic chamber  will work just fine. For Home power,  water sonoluminescence is extreme power!.
Slovenia
Thanks Power To Be for your quick response back to us.  We really appreciate you hanging in there with us.  Thanks Very Much!!
Quote from: The Power To Be on March 19, 2011, 02:11:33 PM
Slovenia,
The DC fan was a quick approcah to moving fog for water injection, not practical due to auto operating conditions but gives a demo of how to move fog out. Ionic air or electric wind is much more feasible. HHO will freely flow out of the chamber but you still need to move atomize fog to help in cooling of ICE.
For circuit, you dont need anything fancy, the Nebulizer circuit will work and you can put one together with readily available parts.
In Sonochemistry, the higher the frequency, the higher the effeciency lowering wattage. This is easily done by increasing voltage alone.
Acoustic dissociation of water wil cease at higher frequency above few mhz. If you employ electric wind or ion influence, other effects occurs too.
Brass is a great material, optimal effeciency can be utilized at a later stage to fine tune performance and scale down the device into a smaller size.
The Power To Be
a good read on water sonoluminescence.
http://gutengroup.mcb.arizona.edu/Publications/Gutenkunst2002.pdf
ultrasonic waves can be concentrated wth horns etc, and reciever such as tuning fork amplifies effect. ion influence accelerates implosion effect.
