Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
ramset
Chef,
What the heck is Richard Willis doing ? Do you have any info to prove that the Million man  hour device that bolt showed pics of being dissasembled on the bench,is a fraud?
Chet
Thanks Grandma
bolt
Quote from: Chef on March 14, 2011, 06:00:12 AM
This is typical real life bullshitting  :P
Show me please only one system with hard cold proof and measurement, where output energy exceed input energy by any amount! The truth is you can't! You can talk about imagined devices, with imagined overunity performance, and I am sure lot of people will eat your words,and wetting their pussys, but in real life somehow all of these devices fail to produce the claimed results!
Funny, isn't it?  :-\
Oh yes i can! Ismael MEG has a COP of 2.7 and measured and tested on Dyno by Philippine government DOE giving OU at 134% on the wheels. Its not his MEG is anything special far from it but its the first time a device in recent history has been properly tested by a Government agency.
I also have seen looped RV's over skype about 3 years ago and watched it for over an hour. For every 1 public disclosure there are about 100 more that rather stay out of the limelight. If you prefer to believe there is no such thing as an OU device then that's fine im not out to convince you or anyone else of anything.  I just inform and you do your own homework.
giantkiller
Shorting on the peaks makes it look like hash on DC.  ;)
Quote from Masterplaster
QuoteI have a feeling that on collapse of the holding force, the earths magnetic field over compensates and that is the bounty.
Yep... She hates a vacuum.
Here is my version from the previous Falstad sim that I wrote.
The input sine freq is arbitrary at 44hz. The 555s are timed for this.
bolt
GK correct as coil shorting attenuates BEMF as the signal is modulated where it can be extracted using high pass filters. TO gain OU within electrical systems method to be applied must provide source to load isolation from the effects of BEMF. Typically this happens in symmetrical systems where the i/p is directly affected by the o/p.
The greater the isolation the greater the COP as effect of Asymmetric Modulation or Asymmetric Generation can be applied to break the symmetry so we operate outside of book rules and lead into OU devices.  Special Coil construction need to be applied in most cases to drive offset flux on the bloch wall or use flat Tesla Bifilar coils driving perpendicular coil to provide 90 degree offset to prevent BEMF. Use of embedded Cap-inductor alike Don Smith Dipole. Coincidently the math and theory support either a dipole passing a cap layer OR inductors within a capacitor to break the BEMF symmetry.
Toroidal  cores can be wound and interfaced 90 degrees to each other to allow only magnetic coupling without BEMF as JLN solid state orbo has merit.
Normal transformers can NOT be used will always be symmetrical and lead to a loss. However new 90 degree windings can be made to reduce symmetry. Generators require end fired Inductors as ferrites  perpendicular to magnetic field but operated in Scaler operation create anti-lugging.
RV creates high VARS very easy. OU manifest as VARS increases kinetic energy while current and voltage operate in high VSWR or PF 0 as standing waves = Scalar Operation.  Result is massive increase in magnetic flux converts to torque while performing work on very low watts as per Joe Newman motor runs on a few PP3 batteries.
To convert VARS to Watts use asymmetrical device as above to keep symmetry broken and maintain the Dipole.
Those that have done this and proves it works you can step up to the plate. Open minded people needs to retune their thinking. Debunkers can fck off as no time left to play games.
