Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
MrMag
Quote from: Rosemary Ainslie on June 29, 2011, 01:31:23 AM
Golly Bubba. That's some interesting math.  ;D
And Evolvingape - I've told you the answer.  40 ampere hours from a 12 volt battery supply gives 480 watt hours.  Therefore  it theoretically can provide 480 watts for each second over the period of a single hour.  And with 5 of those batteries we've got a potential of 2.4 KWH which is simply five times more.  Apparently it's not correct because each battery has got different ratings.  Some can discharge heavy currents and others can't.  Therefore the watt hour rating is simply a guide to its potential work output.  No wonder I wasn't allowed to include those battery draw down tests for our Quantum paper.
Regards,
Rosemary
That's we are politely asking you to do the continuous test. Just let the setup run. No need to take any continuous measurements, only the battery voltage to start and then at the end. It's very simple. This test doesn't care if all of your batteries are different. If your circuit is OU, the batteries will maintain their voltage. If not, they will die down.
evolvingape
Quote from: evolvingape on June 28, 2011, 09:51:10 PM
And as for the battery lets use the model in Rose's circuit. Please tell me EXACTLY how much energy is in each of the individual 5 battery's.
RM :)
Regards,
Rosemary
Thankyou Rose, you have just demonstrated clearly and concisely that you do not have the slightest idea of what I am talking about. You have just earned yourself a double facepalm for an Epic Fail!
The question was for Wilby anyway, so Wilby, please tell me EXACTLY how much energy is in each of the individual 5 battery's in Rose's circuit ?
RM :)
Rosemary Ainslie
Quote from: evolvingape on June 29, 2011, 04:23:18 PM
RM :)
Like I said.  God help us all.  Guys I'll get back here when I've finished that paper.  Meanwhile Wilby just let them rabbit on.
Regards,
Rosemary
Magluvin
RM :)
Dude, I agree with Wilby on the battery thing. its a loaded question.
You could have 50 new fully charged batteries and they will all hold some differences. When loaded in series they will even out as close as possible to eachother except for the little differences I spoke of. With batteries in series its called balancing out.  After a full charge, some may contain more energy than others. After the full charge if you put a maintaining charge to them, in series, balancing will occur and most all will be close to equal.
Big caps is the way to go. The energy involved is finite when you know the value of the cap and the voltage in that cap.
Mags
Rosemary Ainslie
Quote from: Magluvin on June 29, 2011, 06:53:17 PM
Mags
We'll be trying that caps test soon Magsy. Hopefully as soon as this weekend.
Rosie
