Japan Disaster and The affects of the Suns pole reversal.
Started by Blvir, March 12, 2011, 12:17:35 PM
What are going to do about it?
USE Your devices in Public.
3 (37.5%)
Teach your community about FREE ENERGY!
4 (50%)
Have documentary showings in your community.
2 (25%)
Educate your neighbors about the truth.
4 (50%)
Total Members Voted: 8
Voting closed: March 22, 2011, 01:17:35 PM
raburgeson
That was years ago. The tread title was Thermite burns under water at the overunity site at yahoo.com. Like I said our equipment was crude. You need to make 2. You have waste to clean out from the boiler. A little thought put into this and the waste could be removed quickly. Liquid steel does not stick to brass. An hour glass shaped brass collector could be made with a valve in the center for removal. A real combustion area could be made and a feed system.
We used a boiler with a funnel shaped bottom and a high pressure pump from a scrap rubber press. Water was pumped through a vent in the side that made the water swirl like an emptying toilet. The cracker sized wafers of thermite were fed in clip style from the top. Some were not lit by other wafers and some wafers melted holes in the bottom of the boiler, hot enough to stick. This needs developed, we only proved it is a viable way to produce a tremendous amount of steam energy. If you have rocket nozzle material or a high temperature material like it for a real combustion area. We did it to point the way. We were not trying to build a large electric plant. It's just something we gave freely trying to make the world a lot safer. We hoped someone would work on it while we worked on other things.
Right now we have lost count of the thousands we have tied up in our present project and if we can achieve results we will post them here. Small scale you are still looking at enough steam to to produce a lot of electric. We would like to see pellets the size of building bricks and a real serious energy plant made for this fuel. It is hot and stable.
