The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Quote from: AmericanMan31 on September 08, 2011, 01:58:43 PM
I am very excited, and have a good feeling about working with bismuth because #1 of its diamagnetic properties.
            #2 its low melting/forming temp.
            #3 its likely viable resource in antigravitics and cop>1
yes :)
Hope
I reviewed the EBM generator (Electricity By Movement) so this is what is working already.  We must spin the inner or outer coil physically or both in opposite directions.   Share this if you want.   (And God's spirit MOVED upon the face of the waters)  It's surface tension is disrupted and it uses natural energies to reform this surface tension.  It is the same with all organized matter.
It is called cohesive disruption and nature uses it's abundant energy to rebuild this cohesion.  Same with coil shorting it just a different wavelength that has a nature surface cohesion and is disrupted and returns to a surface cohesion using natural energies.  We commonly call it surface tension when it is water we are working with.
We COULD make a solid state device but it would require nano sized wire windings to get high efficiency out of it.  But just spinning one or both wound cores will do it cheaper with all partials interacting.  Disrupting there cohesive balance they have achieved acting on each other in the static (non moving) condition.
Hope
So Mavendex you were VERY correct that we have to make vortex action and this is simple if we just physically spin the coil(s).
matthewklinko
Hello I have found out that my previous design had a very low perm inner core, and hence little voltage was being transferred across..
I have had a new core built up with a perm of 61k.
The design is attached, let me know what you guys think
Matthew
Magluvin
Hey Mat
Very interesting, that cross section view..   All these cores are square edged?
hmm, I wonder if round would be a better choice if available. Maybe have the square machined down.  There is a lot of room in the shell being wasted and maybe a problem.
To me, I would want no voids as I see in your drawing. Not faulting you here.  ;]
Thanks for showing
@American
Thanks. There may be many ways of doing this. And Im weird.   ;D    It just seems that many have tried the shell and seems only Mav has anything really going but not satisfied yet. So pondering a different geometry may just take a little thinking and trials.  But Im feeling good about the alternatives more as I think about it.
Mags
