0 Members and 175 Guests are viewing this topic.
LarryC
Wayne,
The patent diagrams have done much to clear up the system process comments in your previous post. It also proves, that as you stated, you have been completely honest in your post. Thank you, this has not always been the case here, and it may restore faith in some.
Your post have given the impression that the overunity is coming from the air pressure in the lifted ZED to supply half the pressure to the other ZED for precharge. This makes sense at a base level, but I don't see how to mathematically solve it.
'Do not forget - We prove it on paper using simple and also complex physics. (note to future free energy inventors - if it does not work in the simple math - it will not get better in the complex).'
Can you show the math proving the overunity?
Regards,
Larry
mrwayne
Quote from: LarryC on June 06, 2012, 12:49:29 PM
Wayne,
Regards,
Larry
Hello Larry,
I have a meeting in ten, so I will say - this is a good question, and I apprecaite your logic and wisdom.
Staying honest it the only way to go. Sorry about those that do not hold that value.
I will answer later - I am not a engineer so my answer will be in - inventor - test and rest type language.
Thank you Wayne
johnny874
Quote from: mrwayne on June 06, 2012, 12:06:33 PM
The difference between my designs and yours is that I
use mechanical means which can be tested independently.
                                                    Jim
Hello Jim,
I have no idea of your system - so comparisons are confusing, and good luck.
Again, thanks for your input - when you do understand our process - I hope you are as excited as we are.
Good Luck on your pump.
Wayne
Wayne,
Unfortunately I do understand what you are trying to do. I would say you are in a state of denial.
You spend a lot of money and put a lot of work into something and it doesn't work. Something it
seems you are having trouble accepting. Spending more money further complicating it won't get it to work.
I wish there was someone else who could get you to understand this. Using an air pump to increase
the "bouyancy" effect is basically converting air pressure into hydraulic pressure. There is nothing in your
system that amplifies the potential for work to be performed.
Maybe one day you'll understand being a part of something is better than being on top of the mountain.
        Jim
mrwayne
Quote from: johnny874 on June 06, 2012, 01:14:32 PM
  Wayne,
        Jim
Once again,
We do not use an air pump - (after initialization)
It is not denial my friend -
What 'you' think we have - your are right - but what we have 'you' do not understand.
Thanks
Wayne
telecom
Quote from: mrwayne on June 06, 2012, 01:26:29 PM
Once again,
Thanks
Wayne
hi Wayne,
how many cycles it can run until the next initialization?
Alex
