mrwayne
Quote from: neptune on June 11, 2012, 04:12:22 PM
. The pressure at any point in the system is Inlet pressure minus 0.43 x total height of water columns between inlet and measurement point. This formula does not quite work exactly.
Hello Neptune:
Your on the formula - starting from the outside moving in - the pressure increases (charged) dirctly related to the head and previous head at any given point -
This is not the total hieght x head --- but specifically where the distance is measured (on a connected column of water - inside a layer ) from surface to surface - on that same column.
Little confusing - if one side of the same body of water has six feet and the other has two feet - you have four feet of head ...so  4 X .43 = 1.72 psi
(before I go much further on this - please notice that to increase the head 2 feet - you only need to move one side 1 foot) Big point.
When I said we get 24 feet worth of head by moving three feet - 24 feet were possible - four layers, activated by moving one layer 3 feet - no where else in the world ....
And of course the total head is the direct route to the total force available.
Your in a can of worms now, please ask specific questions around this one.
Wayne
prato_braun
Hey guys,
my guess recording to demo 5  is that even if you have to put in more energy to push down the cup the first time you could harvest that indefinitely considering a system using up and down strokes. I mean in the left cup you would have to remove and add always more air than in the right system once the cup is set in the initial position.
It becomes also apparent in the downward travis effect as once the construction is built in set up you would always have to pump out less water on the right than on the left.
That's how I understood it so far and please point out if I got it wrong. I will look at the patent, too as the drawings so far didn't give me the 'aha'-effect yet.
Keep us updated and good luck.
Prato
mrwayne
Hello group,
Just saw a video of a non aquantince - Tommy Reed.
Here is a link: http://www.youtube.com/watch?v=j2S0taX_1rg
Tommy claims I refuse to answer questions WOW........
I refuse to answer snotty insults laden statements, but never heard from Tommy.
And Tommy states that my generator is powering a hydraulic pump..... from secret wires.
Do ya thing Mark Dansie would have caught that one???
Tommy points to the pressure transducer cables.....
We did not have the generator and motor running when Mark took the video of the Zed system running last November - We have released two videos - with and without the Generator pump running - poor homework Tommy.
The hydraulic MOTOR and GENERATOR was an upgrade for the final critical review.
Tommy owes me an apology, better be quick.
Let me state Publically - He has never spoken to me, nor asked me a question - unless he used a bogus name, Tommy has slandered me, and lied about our process.
I suggest a little homework is done before slandering a good man's character.
Tommy, You have 24 hours to remove that unsubstantiated slander against me, and Apologize - or you
will answer.
You have your fame - and I will follow through, I can back up our claims - with our machine and in court.
Wayne Travis
johnny874
 Wayne,
aoy chance you can post a battery free video ?
mrwayne
I will have my son make a video tracing the wires to where they go - which is directly from the 3 phase ac generator to the rectifier and then directly to the little 12 batteries that power the sensors, record the data - activate the hydraullic valves and power run program. oh yeah and power the light s for fun.
Wayne
