W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
gauschor
@Bruce: I'm sorry, I still don't get it. Pardon me for these questions, because I might have understood something wrong.
These are the mentioned utils we need:
a base 2x4 will do maybe 12 inches long
a riser to attach a pendulum too
a pendulum
a weight attached to the pendulum
a way of limiting the movement of the base ( see dia )
a couple rollers for under the base
But then protech talks about a lever which is not listed. And you say I should attach a lever. Which lever? And where exactly should I attach a lever? And is this lever connected to anything? And with what purpose? There is some information missing.
The "riser" is the pillar I assume, therefore not the "lever". No lever shown in the sketch either.
I also don't think the lever is the axis where the pendulum is attached and which is on the pillar, because it would be called "axis".
Bruce_TPU
Quote from: gauschor on April 28, 2011, 10:51:18 AM
Hi gauschor,
http://www.overunity.com/index.php?topic=10659.msg283020#msg283020
Now, Bill says "to the fulcrum", so it must be either A) above or B) in front of.   My guess is (B) because it would eliminate the twisting that dreamthinkbuild was speaking of.
The lever is attached to the pendulum and moves with the pendulum.  You want your pendulum to be stiff, not wire or rope, etc.
See pic below -
Cheers,
Bruce
gauschor
Aaaah, thank you very much for this sketch and explanation, I understand now.
friendenergy
well I sure don't get the lever idea at all. You would think he would put a 20 inch huge lever in his drawings. It might be just miss wording and protech won't clear it up. Wondering if it's an idea we all get and think it should work but need others to build it just to make sure. No offense Protech but if I built something that works for ever and keeps going back and forth I would be much more understanding and help other make it.
am1ll3r
Hi Everyone,
Using Phun I put this test video together. Proportion and timing are all off but I think this is the basic idea.
http://www.youtube.com/watch?v=7R-ypRlo8TY
Cheers,
Chris
