W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
gauschor
Ok, this device built after the sketch alone will obviously not work. Now the question is how can we use the lever in a way that the device never stops or even create excess energy. I guess this is the part where we must use BRIAN, otherwise we are "realty stupid" :(
The tug shall lift a beer bottle: this in itself could of course be something like excess energy - maybe this is all he wanted to tell us: the swinging pendulum will diminish each time, however the tug is so large that - if we could feedback that power to the swinging pendulum (combined with the correct timing...) we are done. Therefore the device in the picture he showed us could indeed be overunity, it's just not that obvious at the first moment.
This also explains why he said the picture is only "Stage1" and he is at "Stage5". I am not sure though how we can use this lever to achive what we need.
Bruce_TPU
Quote from: gauschor on April 29, 2011, 05:56:18 AM
Hi gauschor,
What if the lever uses a pully to lift a weight, and then, with the correct timing releases it again??  Utilize a pulley, and latch.
Or maybe the lever opens a spring, a certain tension is reached and the springs closes, giving back a little force to the levers downswing!
Cheers,
Brucer
Bruce_TPU
Quote from: Bruce_TPU on April 29, 2011, 07:50:32 AM
Hi gauschor,
Yes, I think. We need to add tension.  Perhaps a rubber band, or several, until the right tension is found.
Cheers,
Brucer
bourne
I don't want to be seen as completely negative towards this thread, but I think I might have something to add.
After reading the posts about the lever, I think Bruce's picture (reply #76) is wrong.
I think what is required is the lever be mounted 'through' the axle of the swing point as you have it now, enabling the pendulum to move up and down balancing the weight of the pendulum (1unit in front of upright 20 behind upright). This with the carriages side to side movement will allow the pivot or swing point of the pendulum to  move in a circle relative to its movement.
Just like your hand would do when swinging a ball on a string, make little circles to keep the ball constantly accelerating.
I hope this helps :)
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
neptune
We are given a list of materials , and it does not include any pulleys or springs . I am reminded of a rhyme from the story of Rumplestiltskin .
Although today I brew and bake ,
tomorrow the Queens own child I`ll Take ,
THIS GUESSING GAME YOU`LL NEVER WIN,
Coz my name is Rumplestiltskin .
