Thanks to ALL for your help!!
Petrovoltaic Cells
Started by ibpointless2, May 02, 2011, 08:40:56 PM
gravityblock
Quote from: ibpointless2 on May 02, 2011, 08:40:56 PM
This one puzzles me a little but the glue cell was affected by mass of objects near it. could be the gravity waves or the gravitational field on the mass and the cells are picking it up.
http://www.youtube.com/watch?v=Ch7poA8vmmE
Electromagnetic fields carry energy, momentum, and angular momentum. The momentum density accounts among other things for the pressure of light. But even static fields can carry momentum, and this would appear to contradict a general theorem that the total momentum of a closed system is zero if its center of energy is at rest. In such cases, there must be some other non-electromagnetic momenta that cancel the field momentum. What is the nature of this “hidden momentum” and what happens to it when the electromagnetic fields are turned off?
Hidden momentum, field momentum, and electromagnetic impulse - www.physics.smu.edu/scalise/P7312sp11/HiddenMomentum.pdf
GB
ramset
Bump
Had mentioned this To Smokey
and I see there is a recent topic started here with a few experiments
http://www.energeticforum.com/renewable-energy/20920-petrovoltaics.html
mostly curious about the Electret aspect and holding Charge for some experiments being proposed
recently.
Thanks Grandma
Kator01
                        ibpointless2,inreresting your glue-experiment.
Now check this out. I watched Dr.Egely´s interview ( 2013 ) The subjet starts at min 12:19
He giveshis talk in english which is interpreted to tschechoslowakian
https://www.youtube.com/watch?v=iSenorAkK_E
What he did not tell the public in this demonstration is what he confessed in another rather private interview which I had seen before:
The material between the two aluminium-plates is just simple household-glue !
I am very glad that I had archived it back then
Mike
Vladokv
ramset
if you have not watched the interview with Dr.Egely posted By Kator 01
you should !!
keep watching past the referenced 12:19 / image he linked above ...to the transmutation of elements in a simple microwave with pencil carbon to iron !
again here
Thanks Grandma
