Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
plengo
FYI: today I had my cisco router "bricked" by an outside party. The attack has been very well designed with the intention to kill my router, which they succeed.
I had to by a new router for another $150.00. I don't see this as a coincidence, but I am crazy anyway.
Fausto.
ps: more progress done today. I got the rotor balanced with the shaft, bearings and stators. I will setup the coil connections tomorrow.
infringer
Plengo how did they brick your cisco router ? Were you running third party firmware "DDWRT" on your router?
I find claims like this rather amazing not to say that it is impossible but it is not likely someone just bricked your cisco router...
You could do this by uploading a bunk firmware to the router sure but you would first need wired access to it or it would fail... I am sure something could be scripted to do it but very few people are capeable of such a thing really.
It would be likely more easy to turn up the output of the antenna signal to something high to make your router burn up in a jiffy if you were running DDWRT or something of that nature.
Secure your wireless connection surely nothing is 100% secure and I'm sure I could figure out your password with backtrack likely by salting a gigantic password list but it would likely take a while if you were using WPA2 PSK ... But to actually brick your router that is a whole different story wireless bricking requires a fairly extensive knowledge of your particular router unless as I said you are running a 3rd party firmware.
Possible but not likely.
While I doubt the MIB's are after you and this is just sheer coincidence good luck with your build off to a good start.
150bux for a router sheesh I have three wireless n cisco routers laying around here I would've sold you for like 30.00 plus shipping sheesh! Must be one hell of a router mind if I ask you which model you had and which model you currently bought?
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
plengo
I know!!!! And it is Bricked for good. I try every trick on the net to revive it but no luck. I had a Linksys E2000. First time I was using a simple password. No DDWRT.
My new router is NetGear-N750, much faster than the previous one and this time only MAC address of my stuff will be allowed.
I am very surprised too but this is actually the third time that happened. The first time I did not know anything about routers but after twice I studied a little bit and now I know a lot more. Whoever is doing this is doing in purpose because is not the first time. I have no idea why but It all started after my first videos on Youtube about free energy. Figures!!!
I don't think it is MIBs, they have more important things to do and off course they could simply knock my door and take everything without any hassles, after all this is USA the country of "freedom".
Fausto.
infringer
lol fausto a mac address protection is alright but that is what they use to grab your packets they knock a connection off with a mac address and sit in the middle I could set my wireless mac address to whatever I want.
If they are that hard core where they can brick your router a mac address protection will not help you. Anyhow it is possible that you are having brown outs or whatever I have the equvialents to the e2000 routers. Bummer I am sorry you have had these issues with routers but I would invest in a surge strip or better yet a UPS to protect this at that rate cause surge strips prevent spikes ups will prevent spikes and lows aka brown out conditions you could actually cause these conditions if you have too much hooked into the same breaker.
I think it is coincidence bud nothing to worry about. As far as someone bricking your router.
I do however understand your views on the US not being constitutional as of late we have really went out of our way to overturn the rules that this great nation was founded on and even then there are government agencies that do not have to follow any rules most times they are companies that are hired to work outside of the rules that law enforcement must abide by.
But in your case I think you are safe.
-infringer-
plengo
Today i started my Romero/Muller and guess what happens? nothing. The coils are absolutely the wrong resistance, 150+ohms is too high and does not allow much current consequently much attractive/repulsive magnetic field. It could be also the wrong cores.
I was suspicious this would happened and that's why I ordered the Litz wire but they are taking soooooo long to get here.
I changed the ball bearings for my ceramic and still no good. So it is not the friction but the coils. The good thing about those relay coils is that they create a lot of voltage just by spinning the rotor at 10 rpm or less, very impressive.
I may switch just the driving coils with coils of less than one ohm and see what happens.
One thing is for sure, if this motor was a scam, it means that Romero spent a good amount of money a time just to fake it because this is not a simple Bedini SSG motor. It is very tricky and as toranarod said, there are lots of places for tunning and research.
Fausto.
