Thanks to ALL for your help!!
A Test to Prove Gravity Has Mass
Started by brian334, June 01, 2011, 04:39:08 PM
brian334
There are some really daum over educated people that think the mass of a object changes when the object is moving.
This is the proposed test to prove gravity has mass.
Accelerate a particle in a particle accelerator and measure the impact force of the particle in different gravitational fields.
If gravity does not have mass than the impact force of the particle will not change in different gravitational field.
But if gravity does have mass the impact force of the particle will change in different gravitational fields.
When a particle moves thru something that has mass, some of whatever the particle is moving thru is moving with the particle. When said particle makes a impact the force of the impact will be a combination of the mass and the momentum of both the particle and whatever it is moving thru.
So if gravity does not have mass than the impact force of the particle will not change in different gravitational fields. But if the impact force of the particle does change in different gravitational fields than gravity must have mass.
brian334
6/1/2011
gravityblock
Dr. Ricardo Carezani's experiment (Video), http://www.youtube.com/watch?v=6Lzd86ZYf_o&feature=related
A photon has zero rest mass, but has a relativistic mass due to velocity.  Light remains stationary unless moved by mass, while space-time and mass undergoes expansion acceleration, http://energeticforum.com/renewable-energy/showthread.php?t=8058
GB
brian334
sm0ky2
@ GB
i usually respect your point of view on the subject of gravity,
but the pico-graviton experiment, may not actually demonstrate what the author is implying there....
There is an obvious alternative solution, in that the "gap" between the masses varies the attractive force of gravity eminating from the larger masses, therefore subjecting the barbell to the more-effective attractive forces of the smaller masses.
This can be demonstrated by pushing the larger masses together, removing the "gap", and the barbell will always attract towards the larger mass.
AB Hammer
brian334
For gravity to have mass. Wouldn't this say that gravity is a pushing force and not a pulling force? This would also mean that space is like that of water the deeper you get the greater the pressure. This would also mean that the pressure in space is always greater around the larger the object is for there is more that pushes back from due to mass.
Has gravity been proven to be a pull force and not a push force beyond all reasonable doubt? Accepted yes, but how about proved?
Alan
Alan
