New magnetic-gravity motor chasing its tail from Tom
Started by hartiberlin, June 05, 2011, 12:43:40 PM
forest
lumen
I can't imagine this, english is not my native language.Can you draw simple picture of it ?
ramset
Lumen
Quote:
Ok, I'm going to try to describe what I believe is the minimum configuration of Tom's 2 sphere magnet motor.
You need a turntable that moves very easily and two sphere magnets and some thin brass rod.
Suspend above the exact center of the turntable, one sphere magnet with north directly up(vertical), attached to the brass rod that is in turn connected to a stationary mount. The rod needs to be just long enough to have some flex which is in turn dependent on the size of magnets used.
Now attach to other sphere magnet to the turntable with north and south on the horizontal plane with both poles an equal distance from the magnet on the rod. This causes a twisting force on the suspended magnet and flexes the rod moving the suspended magnet off center of the turntable.
Now, with the magnet on the turntable at a height that matches the suspended magnet and twisted to 90 degrees of the suspended magnet, no repel or attraction will occur, but if the magnet is twisted slightly more or less then an attraction or repel exists. Remember, you lost some twist because the magnet on the rod twisted some in flexing the rod, so you need to adjust the magnet on the turntable slightly to re-calibrate the neutral point.
Because the suspended magnet is now off center of the turntable, the table will rotate from any attraction or repel to the suspended magnet on the rod.
Way too simple!
I think the fire is started, so now we can all watch it burn!
Lumen
I don't even have a good excuse like Forest
But  ,Is there any way you could post a drawing?
This design has been in my head as  a stroke of genious ....and your design Begs for a closer look and trial test/experiment.
Please??
@Airstriker
So hows Tings??
Thanks
Chet
Oh
BTW
I hope you fellows have been watching here
http://www.overunity.com/index.php?topic=11303.msg298128#new
When iot rains it pours sometimes!!
Thanks Grandma
lumen
Well, I just tested the two sphere design and ZIP.... nothing  :'(
I was sure this was the key but it seems the two sphere secret is safe with Tom.
Something there but just cant pin point it.
penno64
Hi Lumen,
Don't be sure that you are incorrect just yet.
Keep in mind that it is DIFFICULT to identify poles on spheres and then, keep them
orientated that way.
I followed your description and thought, this isn't half bad.
Certainly, gravity, with Tom's first incarnation is easier to picture but, all of my large ring
magnets appear to have spots (areas) that are not consistent. (taken from large loud speakers).
Persist, I think you will be surprised.
Penno
ramset
Lumen
I agree with Penno,
One question,why Brass?,We see the Magnet and Copper have a "Huge" Lenz Issue [the sphere in the copper/aluminum tube drop],Brass Not that far away from Copper!
Probably a silly point at this point ,But?
Chet
Thanks Grandma
