Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
SchubertReijiMaigo
Yeah !!! +1 ElectricGoose, today I made some simulation about this magnetic current theory, effectively with a coaxial wire like, you can transmit magnetic wave over long distance, it look like a wave guide with little losses, see the schematics and comments about this:
ronotte
Carefully analyzing the setup I do not find evidence of any complex circuitry or anything resonant stuff as required to operate at 50 Hz/230V. This is the reason why I tend to exclude any Tesla tie. I experimented last year for about 6 months and implemented most of the Tesla TMT variations...). On the contrary the shown 'magnetic' connection is evident. It is also difficult to asses any OU effects as the whole should operate a bit worst than a normal transformer due to higher losses in the long magnetic connection between the two cores.
ronotte
pese
This invention is fully different, with all schematics that uses sparkgaps
sparks from generator (collector) enz (also JT inverters enz)
al them working with RF (High Frequenies) so it was used, by Tesla
(included  the hairpin circuit) and more. Also Kapanadze tryed to generate
Power in this way, its never can create more power out than in.
ALL that was showned, are faults an errors in mesurements the in and output!
No one can (or will?) this do correctly.
THIS "Serbian Inventor, have found another way that have nothing to do,
with this old system, (also existing on wire power systemas thas was patended
in the ´30s.)
In the first tread it is onnonced that "non herzial . longitually waves
(that are not understanding now, and nobody have used this -except Tesla-
in non fully published experiments )
Give also attention.
It claims,  it can by toutching.
The RF Circiuts TESL Kapanadze , you must not do this.
2. The filament lamps glow (ligtning)
if connected with ONE Wire only.
All HF- Test with lamps (as know from radio amateurs)
as in Tesla Hairpin circuit , and in Kapanadze circuits.
NOT one of them can work with an single 1 wire connection !!
(Not One filament (ohmic) Lamp.
CFL lamps, Leds with less tham some milliamps , neon tube can
work with one wire !! IF YOU HOLD THEM IN THE AND!
Why?
Because your hand (on long neon tubes to the surround , have an
capacitive resitance wit picofarads to the ground.
That is enought to light this lamps.  Long cfl and neon tubes also
with distance to the oszillating sources.
LOOK not his way, (that i know now nearly 60 years) Starting with 9 years
in fathers radio repair service (tube-radios).
Also i lock now 10 years nearly all alternative sources.
an (unprofessional, noncommercial) collection  you find
in englisch and germann language
http://www.alt-nrg.de/pppp
hartiberlin
@SchubertReijiMaigo
yes, this must it be.
Miletic probably uses a stranded steel wire and splieces off the stranded
wires into 2 halves and then makes a loop, where he feeds in the
electricity from the copper coil like a transformer.
As then the energy is transferred only via magnetic coupling INSIDE the stranded steel wires
it does not matter that the single strands touch each other,
cause they don´t conduct electrical current, but magnetic dipole flipping only.
The energy is probably transmitted inside the wire via electron spin flipping,
so just the magnetic waves travel there inside the wire.
The question surely is, what losses do you get versus just a normal copper wire energy
transfer.
Would be interesting to compare the losses.
Probably the steel wire heats up after some time from the BH curve magnetisation hysteresis losses ?!
So it is more or less only a 1 wire steel core transformer ?!
Regards, Stefan.
