Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
kokoro
First of all, thanks to Thomas Trawöger for his online construction video's about his Power Pyramide V12 !
I think I wanne gives this one a try !
I'am a teacher in electrics and communication systems and living in The Netherlands.
Don't worry, an open-minded one !  ;)
With Quantum Mechanics I can put a lot of learned knowledge away.
It's pretty easy for me to get the materials.
My country uses the metric (mm, cm and meters) system to...but, we use american value pipe system.
8 mm pipe is very special here and not commenly used.
1,5mm copper wire,  not any problem !
1,5mm (black) and 2,5mm (brown/blue/yellow-green) solid wire is basic household wiring here.
1mm, 1,5mm and 2,5mm flexible wiring also here.
We have enough white 1,5mm we can't use (bad order, color is not accepted in 230V / 400V installations here)
So it's good for the projects  :)
12mm Copper Pipe is basic household piping here.
No problem getting 12mm, 22mm, 28mm copper pipe here.
Have some 35mm (we don't have much because high price and only used in special occasions)
I Have already done some test wiring the coils.
But I don't want to cut my 35mm copperpipe unless I'am sure about the length value !
kokoro
For "polarizing" the quartz I have two powersources at home.
1 x 12.5 kV Positive (500uA protection limit)
1 x 12.5 kV Negative (500uA protection limit)
makes 25kV total ("Safe" but very painfull when touched..12.5 kV was really painfull !)
So, Can I join the party ?!
francois.jo
salut,
tout nouveau sur le site ,mais bravo pour la pyramide ,reste a prouver certaines choses ..n'est ce pas simplement
une capture des ondes radio? et l'effet de la pyramide pas évident..mais très possible.il faudrait travailler dessus en radiesthesie ..
salutations
lancerdoom
i have 5.5kv AC volt transformer, can i use this AC volt transformer to charge pyramid power reactor ? if not then how can convert that into DC volts ?
neptune
Do not waste your time on this . Trawoeger is a fraud and a fake of the worst kind .
