Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
k4zep
Good Morning NickZ, Neptune, all,
I first became acquainted with pyramids in the early 60's when small units were supposed to keep razor blades sharp.  "Yah, right!" I said in my youthful know it all attitude and small technical abilities at that time!  But we learn as we age.  The passion that Thomas over the years has kept him working on this and trying to overcome the attitudes and building hurdles that are part of this process.  He is one persistent gentleman.
I believe Thomas does have a basic scaling system that he uses to determine the correct or optimum size of the tubes and number of turns when building the reactor that works for him.  When he is sure of the math, by building the "fat boy" reactor (Hummm wasn't "fat boy" the name of the 1st or 2nd nuke bomb built back in the 40's?)  I feel he will release it all in due time.
Our common problem is to build a working 1 meter reactor FIRST.  After we crawl, we can fly.  It's going to get better I think!  When we get a working pyramid, exponentially the information and design ideas will fly!
The funny thing is when all the parts are laying around the shop, you can do all this in a day.  When you start from scratch in a condo, it takes days and weeks......first to be sure of all the details, then to locate the small parts.......
Respectfully
Ben K4ZEP
NickZ
  The two foot size is something I could do.  I already have a two foot model, but it is a wood frame, and I don't know if that works or not.
   I wonder where Thomas got the idea for the capacitor or reactor.
   I don't understand why this is taking as long as it is.  The reactor can be made in a day or two. The pyramid in just a few hours.  This really in not as complicated as we're making it.  It just needs to be followed exactly, as we see it is not going to work otherwise.
  This may be like the Bashar Space-Time Antenna, which also captures energy from the air, but nobody can replicate it, and make it work.
The fact is that this pyramid does produce power, but it may also require a certain minimum size to see some results.
   I can also make any size pyramid in the back yard. I don't know if you remember the story about Less Brown and the one he built in his yard. The electric force threw him 20 feet across the floor.  That was a big 30 foot model.  So, obtaining much more power may also be possible.
neptune
@ Nickz . You wonder why this is taking so long . The devil is in the details , and I feel that there are a lot of people why do not want to commit scarce resources to a project unless they can give it the very best chance of working . This is especially true of people like me who built an unsuccessful V6 version . At the time there was no mention of nodes and divining . Also , of course , most people on here have day jobs .
      One of the biggest unanswered questions we face , is the way the measurements are applied to the pyramid . See main thread . During the pyramid mania of 2006/7 , this was discussed at great length . I am not sure if the old records exist , and at several hundred pages it would be e big job to check . As I recall , the nearest we got to an answer , was that the measurements were those of the inside of the plaster board shell . That was the theory I used to build the V6 . But it did not work and so proves little . If and when I build another , if no further info is available , I will do the same again . The one definite fact we have is that it is based on equilateral triangles with 60 degree angles .       Here is another strange thing . Thomas warns us not to be guided by classic theory . However , he draws a diagram showing the energy rising vertically from the ground . As it meets the inner surface of the plaster board , it is then reflected horizontally . Now we know ;according to classic physics , that when radiation is reflected from a surface , the angle of incidence is equal to the angle of reflection . So TT`s diagram is only true if the sides of the pyramid are at an angle of 45 degrees to the horizontal . But they are not . They are at 60 degrees . Therefore the radiation would reflect with an upward slope of 30 degrees above the horizontal .  I am not trying to prove anything here ,just sort of thinking aloud .If we look at this from a classic point of view , only a small percentage of the ground radiation would be directed onto the reactor . The ideal theoretical set up would be a reactor as tall as the inside cavity , and a cone shape instead of a pyramid .So whatever we are dealing with here , it does not behave as we might expect .
NickZ
   There may more than just the classic interpretation of how or why there is energy being emitted from or by a pyramid structure.  I have my theories as well, but, I also respect the fact that Thomas has obtained results that no one else has gotten up to now.  I don't think that it really matters as long as it works. That is what is important now.
   I do see some similarity in this method of extracting juice from space, and some of Tesla patents dealing with the subject, which has been further updated to include such things as PRECHARGING the capacitor, or in this case "reactor" by using high voltage.  Funny because I see also a similar effect just on the cement cell that I had shown before, where if I just touch a 9 volt battery to it (dead, with 2v) it will polarize or stimulate the cell to produce more light than it was giving before, both in light intensity, as well as in duration time.
A lot more,  than just the 10 second tap from a dead 2v source may have given to the cell. There is something there, and I think something similar may be happening here.  And may be the reason that nobody has gotten the same results as Thomas.
  I do think that the investment costs are high in comparison to the output produced by the one meter pyramid. For an equal cost (and much less time) one can buy ready made 12 v, 15 watt solar panel and battery set-up that will work, for anyone, that only takes 1/10 the space. So, this idea is still not too cost effective, yet.
Trawoeger
Arbeitsnotiz -Working Notice
Liebe Community, da ich momentan beruflich einen grösseren Auftrag abzuarbeiten habe,bin ich erst wieder gegen Ende des Wochenendes wieder wie gewohnt hier imForum anzutreffen.
Ich bitte umVerständnis
Dear Community
I am in great Stress to serve a greater Order in my Company. I will be back   approx. Sunday evening.
Thanks
Thomas Trawoeger
