Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
onthecuttingedge2005
Quote from: raburgeson on August 03, 2011, 11:09:34 PM
Tesla figured it out and you can too. Intuitiveness, inspiration and all the other things in any combination could get you there. Remember I said if you find what you need and there is an over abundance it becomes easy to share. Right now I'm reading everything I can on torsion field physics hoping I can fire 2 perpendicular torsion fields at a glass of water to see what happens.  Hope I get a little inspiration along the way.
Good luck with your project!
Tesla didn't figure shit out that is not already out in the world today. tell me what we don't already know that Tesla figured out, nothing will become of your argument.
raburgeson
He caused an earthquake with a simple mechanical oscillator. I'll keep it simple for you. let's not get into the fact that he swung the entire Earth like you would swing a transistor. That's how he transmitted power, why he was building Walden Cliff. Arguing is not productive. I did wish you luck on your project. Start light on Maxwell and Tesla and go onto the formulas later. I have work to do.
jbignes5
Quote from: raburgeson on August 03, 2011, 11:44:08 PM
There is proof my friend. But what these guys who come in here screaming that Tesla knew nothing of the sort. He definitely knew something even our own science shuns. He knew more about the AEther and how to modulate it so that it carried the charges back to the source antenna to collect and use at will. These other guys have no clue as to what we are talking about even though it was cleverly hidden in plain sight. He worked with super high potentials and super low currents of the "invented" current they use now and got real power.
When I saw the message you left about the experiment you are gonna do I thought to myself only use the electric field. Regular magnetic fields will not interact with the Medium of the Aether without a push back. So stick with trying to manipulate the Aether to drag in the charges from all around it.
Like I said devise an electrode made from Aluminum. Make the electrode with a ball on the end. Insulate that from the external ball of aluminum and insert it into a hole in the aluminum ball. Fill the ball with water and energize the electrode. What should happen would be the electrode will raise the potential of the water. This will cause the aluminum to pull charges from the outside of the ball twords the ball electrode. The outside aluminum ball is a static shield of sorts and a conduit for charges to flow through. But as the charges enter the shielded internal area they increase the potential of the water even further this of course makes the metal shield equal to the potential in the water and holds the charges via their own inductive value.
Now the trick is to pulse the internal potential value till you get a harmonic response. This could be much higher then mechanical timing would allow. This I think is the reason for the spark gap. It can fire a lot faster at analog speeds. To control the speed of the sparks all you need is a magnetic field going across the flow that is created from the conduction space. This orients the conductors in a 90 degree angle from the flow. This causes cleaner pulses of pure potential. Varying the magnetic flow is how you control the device. Also I am working on another method that might enhance that further. If you squash two magnetic fields together it compresses the network in between the two fields. This causes the voltage to increase in speed clearing the way for another shot. This is much like the hose and water example Except it only appears to become faster because you are increasing the resolution that the conductor space is capable of. Lets say that when there is a pressure from the sides it cleans up the gaps in between the conductors and push them apart a bit in this process. Lets say that you covered a pearl necklace with grease. The grease is the charges. If you were to put a pressure from the sides of the necklace it would compress the grease and it would coat the entire beads. making the gaps appear more prominently. This is an exponential event. Instead of 1 gigahertz you get 1 terahertz or higher. This has to be used with a coil to change or transform the longitudinal pulses into an analog one we are familiar with by using the bounce back effect to give us Both positive and negative swings on our scope and give it more power by down converting to a higher concentration of the charges.
What I suspect is that we only need to make sure the container has a bidirectional switch of sorts. This could be Diodes and why Tesla used them in the form of vacuum tubes. This would make the tube more analog and better able to handle the increased speed of the pulses because the vacuum is merely a space filled with only conductors of the Aether. Glass being a charge heavy source of Aether will not pass Aether as well and has a limit to the amount of charges it can block. But the Aether is still in there. Maybe at a lower amount seeing that it is an opaque matter. Glass can be used around the electrode in the aluminum ball or a special plastic could be used more effectively maybe even mica could be used if you could mold it around the electrode stem.
How does that sound?
jbignes5
 I went for a walk today and it dawned on me how this energy is being changed.
I have talked about the medium of Aether and how it can attract itself and cause a flow to happen. Now I'm gonna blow that out of the water and let you know how this works on the larger scales like solar systems or even Universes.
Think of the medium of Aether as a gelatin flat disk and all matter is sprinkled on the surface. Matter on that level is always round in masses like planets or any body bigger then the smallest moon. The Aether is spinning like a record player and the earth is spinning with the south pole being the needle riding in the groove of time. Time is merely the grove structure seen from the cross section. Skip a groove outwards and you skip time, like wise jump a grove twords the center and you go back in time. Time is recorded and ripples go out both forward in time and further backwards in time. Just like the ripples on a pond radiate outwards or even the ripples in the flow of a river. For a short period of time the ripples keep going down the river and as it flows the ripples gently dissipates. And so does time. So time travel on the whole is impossible for our matter. But signals in the energy are not effected. They tend to stay longer and radiate back into the time grooves via the ripples recorded before or the previous groove. We could then take a receiver for say a signal and shift the phase to our time by intercepting the signal with the shift in phase and view it in our time frame. This would only work for signals because we can use devices to view with that see way more then were are capable of. For instance heat camera or xray cameras. But that is only speculation at the moment. Util my theory gets proofed It all is speculation.
Lets take this further to understand that the matter that is rolling on this disk is caught but the sources around which the disk is emitted from. A very weak black hole in the case of our solar systems. These are balanced miniature blackholes usually of the outward kind. The in is actually tied to a pair black hole of the opposite polarity and spin. This is because the other black hole is on the other side of a spinning disk or opposite spinning disk that we have from the black hole. There are two different disks spinning in the opposite directions and matter is trapped in between these disks. The plane that is our solar system is the product of two disks spinning around our mini blackhole or sun. The sun is there by virtue of crystals that have formed that block the flow of energy or charges in motion between these two holes on each side of the disks causing the disk like suction. The pair are connected by humongous channels of twisted space because the holes are rigid in that sense. The more these disks spin the smaller the tunnel becomes and the higher the potential of the charges that go through those channels. The spin is based on the polarity of the disk. On the other plane the twist would run backwards from their point of view but look totally normal.
Now lets handle times itself. If one looked at how the record player works one would know that the further out on the disk the more area it would cover in the same amount of time. This is why it looks or appears to be that the universe is speeding up but it is not in reality. Our view is speeding up. We are accelerating through time but our viewpoint is not changing. We don't realize that we are covering more space then we were 2000 years ago. Because our measurement of time is based on the nuclear timing and that is speeding up as well because all matter spins at the base between these disks at the same base speed. These disks are multi-layered and matter tends or stay within the disks on the whole.
We have one disk being pressing onto the other These disks are not in attraction mode but repelling each other and hold themselves together because they are held by the bottle we live in. Very tightly where there is no matter at all this would be the vacuum of space and all charges flow through the squeezed areas and is akin to light like fiber optics working to squeeze the information it transmits and reorient themselves after decompression of the Aether where matter is holding it apart. for us to see in just about the right place it orients from. I don't know too much about this process because this just came to me. Where our earth is there is additional rules that apply and thats inertia and centrifugal forces and also magnetism as we think we understand it. Not by my definition. Magnetism in my definition is purely the Aether moving twords a higher potential. This allows lines to form and give them great potential to pull with. This line is dynamic and very very strong because it self heals as it grows pulling more Aetheric conductors from the condescension of unused conductors from the environment. Remember that the Aethric medium is spinning and imparts part of that spin to all matter because of the conductors contained in matter that matter contains withing it's own particles. Matter is just an anchor of the Aether within it. So it slips to some degree withing the spinning disks. Not truely holding onto the Aether for very long.
Let me know how that sounds. Remember I just thought of this so help me flesh this out. Look for holes in there.
jbignes5
 I don't know if the analogy is right though. I am thinking now that the Aether disk is not rigid in a sense. It is like a pizza when they are spinning the dough. Originally before the flattening out of the mass of charges and conductors there was a huge potential in the center of this mass, much like there is in a very very small charge. The strings are in constant motion in a charge and so is the charges in this mass of huge charges. Since potentials tend to center themselves with the highest potential being in the center of this mass. This means originally the lines were straight from center to outer mass or radiative. But something happened. The extreme potential in the center drew matter to it much like the static force we see in our space. Faster and faster this matter was accelerated twords that potential. This is gravity in the purest form. Once matter started to impact the potential point it created a crystal from the matter that was hitting it. This crystal shot the jets we see in the center of our galaxy. Matter tends to form on these great lines of potential and get pulled along as they move. Once the jets pierced the mass pure conductors flowed back to the source to replenish the missing charges that were being accelerated away. This action also started the great spin we see in our galaxy and it is what causes this great gelatin like disk or charges to spread radially out wards. Not only spread but stretch as well.
Have a look at this:
http://www.kiwispaceplace.com/astronomy-guide-in-our-galaxy.html
The two arms that radiate from the center is the galactic spokes of our wheel and the medium is this disk that matter, even at galactic proportions, sticks to or is attracted to. I think if we are to find life in the universe it would also be in the grove much like we are settled into.
This disk spins way faster then matter can go but it still rolls it along imparting it's energy to it. But the crystals are getting bigger in the center portion of our galaxy. As they get bigger they spin the galaxy faster and we go further away from the center where time is faster or advances more of the Aether through that same time. Things a long time ago grew to mammoth size because the real time was flowing slower meaning matter spun slowly and decayed less. See the Aether does affect matter but it is a subtle effect. Think about this. If matter is spinning merely because it is rolling on the disk via the skin effect then it makes sense that the further you get out of the disk the faster the matter has to roll to cover the same time frame. Since matter is spinning faster we do not see the change in the time but yet more Aether flows by the matter. This wears matter faster and spins up the processes so we don't perceive the change in time. So a second today will see more Aether then a second a million years ago would traverse. We didn't see this effect because we knew little of the Aether and then when we did know we disregarded it because there is no way to see it except for looking for the effects and hence no way to prove it.
That is why we are on a plane so to speak or disk. I believe that we could pull our solar system closer to the center of our galaxy and restore time to become longer. Both lengthening our life spans and fixing the damage it is doing to our matter and the environment. Now how does one accomplish this. Well what is holding us to this solar system. Potential, a huge amount of it would yank us back twords the center of our galaxy to where it was in neolithic time. When I say yank and us I mean our solar system because it is all connected. That is evident by how it stays spinning. raise our potential even on our planet and it feeds back to our anchor the sun. This quiets the sun because we are now rejecting more of the output of the sun and causing it to increase inside the sun giving the sun the ability to draw us back up the line twords the center.
I think this was the original idea behind the pyramids. If we could beam back the energy we capture that would be enough to raise the suns potential and attract us back twords the center potential. This would take a lot of time to accomplish and a greater understanding of the events happening in our universe. What I have wrote down here is merely simplistic ideas all supporting the same thing the Aether. We need this advancement and we need to understand that energy is freely flowing all around us. We figure that mechanic out and we can generate any potential and maybe rescue ourselves from the greed of a few manipulators.
It can be ours. And it can be very free. if you know how to harness the flows. Tesla was a great man at that.
Here is a better look at the milky ways disk.
http://www.atlasoftheuniverse.com/milkyway.html
