Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
0 Members and 38 Guests are viewing this topic.
Magluvin
Quote from: synchro1 on April 18, 2013, 08:21:54 PM
This Tesla series bifilar coil is the closest thing to a free lunch that science has to offer. The SBC charges itself spontaneously as a capacitor, and goes into self resonance as an independent L C tank circuit at the correct frequencies. I believe this SBC tank reonance drives my high speed neo tube in series with a battery and reed switch, when the r.p.m. exceeds the reed switch limit.
Hey Syncro
Are you driving your SBC just as you would a regular coil pulse motor?
Also, are you sending charge back to the battery from the drive coil?
Any circuits you can show?
Thanks
Mags
synchro1
@Mags,
         The two ends of the red wire thread spool SBC: One goes to one end of the reed switch. the other end of the coil wire and the other end of the reed switch connect to the two battery electrodes. Three simple components in series. Secondly, you can see the position of the reed switch over the coil face for running, and lastly: The spinner.
hoptoad
snip..
Quite possible.
Cheers
Magluvin
"the energy stored in the coil will now be two hundred and fifty thousand times as great."
If there is no difference in this coil and a normal coil, why would Tesla state this? Sounds like a HUGE difference to me. Nothing identical about it. And he clearly represents it as compared to a normal coil. ;)
"Capacity secured in this particular way 'possesses an additional advantage' in that it is evenly distributed, a consideration of the greatest importance in many cases, and the results, both as to efficiency and economy, 'are more readily and easily obtained' as the size of the coils, the potential difference, or frequency of the currents are increased."
He clearly states that there is an advantage. Both as to efficiency and economy are more readily and easily obtained.  I read somewhere, I think it was a debate or lecture that Tesla stated that the higher the voltage, the advantages become more apparent. Something like that. Id have to find that.
Mags
Farmhand
Quote from: synchro1 on April 18, 2013, 08:21:03 AM
My discovery:
Four wires wraped together will wind a "Quadfilar coil". Wired as two Tesla serial bifilars, one pulsed D.C will invert the power to A.C. in the other, plus the "Q" coil doubles the pulsed D.C. to A.C. output voltage.
Any resonant transformer can make an AC sine wave from a pulsed DC input.
Tesla coils do it well.
Cheers
EDIT: changed "will make" to "can make".
