Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
That opens the area of Crystal Matrix rechargable types too like we've seen inventers building!
DeepCut
Quote from: synchro1 on March 28, 2013, 08:11:28 PM
I think i've missed a lot !
I wasn't active at all last year, maybe i have some catching up to do ;+}
All the best,
DC.
synchro1
Quote from: DeepCut on March 28, 2013, 08:09:28 PM
Synchro, what do you do when you 'rock' a capacitor bank ?
I'm sure i'm subbed to laser on YT, gotta check.
All the best,
DC.
see saw power back and forth with the motor alternator, while maintaining a sready baseline voltage.
DeepCut
Quote from: synchro1 on March 28, 2013, 08:14:05 PM
Yup, i DEFINITELY got some catching up to do ;+}
All the best,
DC.
Just a comment about Synchro's 2" Sphere clip and the see-saw effect you hear in the first two minutes.  There is a good chance that that's because the battery is close to being discharged.  So the battery "chokes" every few seconds and the voltage drops.  That causes the sphere to slow down, and that results in a significantly reduced load on the battery.  The load is reduced much more than the drop in voltage would suggest.  The battery recovers during this "extra" slow down and comes back with renewed vigor and powers the sphere at high speed again. Then the process starts all over again.  A simple test is to be sure you have a battery that is in good condition and charge it and run the test again and see what happens.
This is a generic phenomenon that can happen with batteries and I have seen it hundreds of times.  If the load on the battery drops suddenly when the battery chokes and the output voltage drops, that "lull"  or "brownout" gives the battery some time to recover and come back again.  So if you let it run a long time, the "brownouts" in the battery output become longer and longer until the battery finally gives up.  Then if you disconnect the battery and wait a day, the battery will seem fresh for perhaps ten minutes next time you run the test and then start to crap out again.
