Ibpointless2 Crystal Cells
triffid
I have not done anything here in months it seems.I was trying to find a way to keep the casmir plates in my epsom salts crystals from coming together.The only way I found to do that was to never draw on the current.Not a happy state of affairs.triffid
triffid
In a soapy water solution, the oils and greases are contained inside a sphere of negative charges.And these negative charges interact with water molecules to be washed away.Now an atom has all of its negative charge on the outside(its electron shells).Seems to be a clue here?
triffid
The cells I made last dec,16,2012 still show voltages ranging from 1.3 volts on down.Of course these cells were not hooked up to anything that would draw current from them.
triffid
I have been working on soap solutions.I still believe that these neg-charged spheres can still keep the casmir plates apart in the epson salts crystals.I believe that just adding a liquid soap was not the right way to to the job.After a while I realized the spheres may not have set up properly.So I saved some dirty dish water from washing dishes two months ago.The "dirty" soapy water is still in suspension.I will soon make more rock battery cells using my "dirty" soapy water.triffid
triffid
After not doing much here for the last 6 months except for looking at dirty soapy water suspensions in my kitchen I made six more rock batteries in an egg carton.I added four regular drops of soapy dirty water from an eye dropper into each cell.I used magnesium strips and copper wire as electrodes.No acid other than whats in the morton salt sub.Tomorrow I will check on the voltages once the glue dries.
I hope that the negative ionic spheres in the soapy water will keep the casmir plates open.If that happens then these cells should keep producing the same amount of volts and amps six months from now as they do at the beginning .Even if they carry a load all that time.triffid
