SMOT
Started by KSW, April 11, 2005, 08:45:18 AM
wizkycho
Quote from: pinobot on June 22, 2005, 05:05:32 PM
Quote from: wizkycho on June 22, 2005, 06:52:15 AM
pinobot
pinobot, If You are not one of the ignorant liers, You will now
provide factual explanation to me and others why do you think that this is not
most advanced SMOT ever made.
thx in advance
There's nothing to explain, the amounth of power transfered between the balls i whats keeping the balls
from moving past the sticky spot in the first place, so its the same as
having 1 ball only worse because you can't use the full length of the ramp.
In this SMOT setup Magnets ARE NOT positioned to make Ramp so ball doesn't have to climb but complete gained energy transferes to the other ball which will (there is no reason it wan't)
ROLLAWAY.....!!!!YupiiYaiYe!!!!!!!.to the next SMOT ........ and so the future begins now !
                         Have You seen Jeans rollaway test exp.
                         Have You seen Adsitts two balls bumps from magnet exp.
Igor Knitel
HardNor
haha 3 posts for one Answer?
wizkycho
additional explanation
there is only one stycky point (stable point) where ball will stuck and this is where magnetizm is strongest at the end of SMOT unit.
That point is very narrow.
If the other accelerated ball with Ek kick the first ball two things happens:
?First ball is more or less removed from it's stable point. (better more than less, depends on Ek of the second ball)
?Now both balls tries to get to that stable point.
?Scince second ball is still in between magnets, flux will mostly be closed around second ball
? ?leaving first ball ALLMOST free to rollaway.....
?When second ball stycks (gains stable point) complete mag flux goes through it and second ball is COMPLETELY
? ?free to rollaway.....to next smot.
to repeat:
? SMOT unit is not ramped - ball is not climbing and it doesn't drop it bumps to next one.
wizkycho
Quote from: HardNor on June 23, 2005, 03:24:57 AM
connection or session is sometimes lost on my PC not telling if the message was sent or not. sorry
wizkycho
Quote from: HardNor on June 22, 2005, 11:21:45 AM
out topic:
why those people never see that real media files suck !?
@wizkycho: i think this smot circle work - i will try to test and improve it
please try it for I don't have NdFeB magnets 25 to 30 cm long. I will but... idea is NOW, replication is...when i get the magnets. You only need two magnets so the north closses with south. One magnet is not sufficient because it will
have opened flux lines at the exit of SMOT so bumped ball might return. and Try to keep distance between
ball (at the exit that will be bumped) and magnets.
