Ghazanfar Ali Generator - Utlilizing trapped energy
Started by Ghazanfar_Ali, February 04, 2012, 03:14:30 AM
ramset
Mr Ali
I appoligize for my post above ,I was honestly confused and thought I was in A "Tito" thread.
These threads have a strange history as well as a "lighter side" [the "TiTo"  threads]
A sincere and Humble appology sir,
Chet
Thanks Grandma
forest
Quote from: Ghazanfar_Ali on July 31, 2012, 03:37:04 AM
As per Don Smith's Teaching:- the two coils side by side in CW and CCW fashion and with same number of turns once connected in such a way that say two ends of CW are 1 and 2 and those of CCW are 3 and 4. 2 and 3 are connected making a center tap and 1 and 4 are connected together. We can get maximum output between the two ends then which are 1-4 and 2-3. And this happens only and only when the coil is in resonance state. At rest of the freqs both the fields will cancel each other. Dave45 gave a very good hint to avoid these cancellation effects and the only solution is resonance through a caduceus coil. Caduceus coil has weird magnetic properties and the new field which is produced is scalar in nature often called Zem field. It has electrogravitic properties once pulsed in the range of micro-wavelength.
Here in schematic the Pri is supoosed to be fed through a train of pulses from 0v to +V. Duty cycle 50% and freq has to be the resonant freq found separately for LC pri and LC sec using a function generator and an Oscilloscope.
Kind Regards
Ghazanfar Ali
Wel.. are you sure about that in bold ?  ::) What I have learn from Tesla is that every problem has to most elegant and simple solution.
From his  autobiography "My inventions" we can read many many very subtle helping tips. The same from patents and lectures and articles.
I will give you one astonishing example: "Another discouraging feature of the high frequency alternator seemed to be the inconstancy of speed which threatened to impose serious limitations to its use. I had already noted in my demonstrations before the American Institution of Electrical Engineers that several times the tune was lost, necessitating readjustment, and did not yet foresee, what I discovered long afterwards, a means of operating a machine of this kind at a speed constant to such a degree as not to vary more than a small fraction of one revolution between the extremes of load."
Ghazanfar_Ali
@Forest
I personally designed a secondary with 7 turns CW and 7 turns CCW and I am getting 50 V between the two ends 1-4 and 2-3. Once I touch these two ends it gives a big sparks but there is no electric shock as the primary is in resonance at 39.1 KHz. But this low voltage at secondary is in the absence of a tunning cap in parallel and its obvious that the secondary is not in resonance with the primary. The max voltage and max current at resonance for such coil is the claim by Don Smith and Zilano as well. I still have to find out soon I get the secondary in resonance with primary. The desired cap I have to get.
Kind Regards
Ghazanfar Ali
Ghazanfar_Ali
@Ramset
No problem Dear. I also apologize for a rude comment.
God Bless U.
Ghazanfar Ali
forest
Quote from: Ghazanfar_Ali on July 31, 2012, 11:01:04 AM
@All
Let me clear a bunch of group, that this website has a feature of messaging privately to good and hardworking members of overunity.com And the posts of diagrams etc which I show here are for those with whom I am working through private messages. The reason of discontinuity to sequence in my posts is obvious for those who are not with me in my research team and emerging for the first time in my thread. And that is the pain they feel and post rubbish here. Get hold of someone very very stupid guy who will present his brain to u in a plate for stealing his ideas. All those with whom I share my ideas are putting in there effort in this field and I am highly obliged to them. They helped me a lot. I again request the administrator to keep a notice to such pathetic posts, coz this rubbish was not there a few months ago. But I cant do nothing if a sweeper gets registered with this forum and starts writing rubbish coz it is in his profession to play in rubbish and heap. If someone has become a hero member by increasing his number of posts, it doesn't mean that he is the only one Hero over here. So please do not disgrace others and yourself by posting rubbish coz then there is no difference between u and an immature Skunk.
Kind Regards
Ghazanfar Ali
Wow! I think your seem to overreact.I think ramset is honest and nice person and didn't wanted to distract your thread with bablish. He is just very emotional about Tito.
I responded because I know you and Dave and Magluvin are close... to something I believe Tito knew also..
I agree with this your statement : "Get hold of someone very very stupid guy who will present his brain to u in a plate for stealing his ideas." Every man putting his heart, time and everything else into inventing things should get the reward for his hard work.I saw many examples of dishonest and crude treatment of inventors.
