Bessler , Karl I! The fat lady is gonna sing , haters bring it I'm not skeered .
Started by christo4_99, June 28, 2012, 06:38:25 AM
ace569er
Though this is just an educated guess....I think the center pendulum is moved by the magnet that tilts the spring as well as the balls weight on the tilted wheel putting pressure on the spring(big one). Also the 3 pendulums are off set to the same side as the very large magnet, on them, is offset on. I think this helps push the center pendulum. If I arrange all repelling magnets in the position shown. Then stop it and just touch it it want to go in that pattern about 2-7 rotations. if you kick it with just one of the three off sets you can keep it going around. I think this is at least somewhat close to what makes the center pendulum move. Sadly everything relys on everything else to run, in my option. so it is hard to test, with a controlled pendulum to push it. yet alone the ball and spring factor. Unless it is completely  built. So I hope this model helps a working replication to be made. Because I want one!!!!!!!!
