Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
PARAV
Quote from: Pascuser on January 16, 2014, 05:47:40 PM
All replication notes are indicated in the posts at the beginning here:
http://www.overunity.com/12639/richard-vialles-new-theory-about-negative-mass-and-overunity/msg337174/#msg337174
http://www.overunity.com/12639/richard-vialles-new-theory-about-negative-mass-and-overunity/msg337176/#msg337176
I had beginned a translation, never achieved because of no interest in english world.
Here is the unfinished translation of the document concrning the 1st generation of autogenerateur:
http://zedico.info/Extraits_Publics/Pascuser/selfgenerator_1.pdf
Hi Pascuser,
Thanx so much for getting back to us on this thread. I can understand your concerns about the English speaking experimenters not jumping on this sooner.
As d3x0r says there seemed to be a lot of information about  building this, was missing for us --but  I attribute this to the lack of understanding the French texts and translations etc.
There is another member "Khwartz" was getting on to this (on the Dally thread today)and I believe he is  bi lingual (English/French).  He and maybe  "Woopy" may be able to help you out in some of the translations for us -in helping us build and test this apparatus.
Looking forward to hearing from all of you.
Paul
d3x0r
Quote from: PARAV on January 16, 2014, 06:20:06 PM
Hi Pascuser,
Paul
@pacuser
Yes and thanks for kindly resharing the links :)
@else
uhmm ya; tesla hairpin circuit? With a closed shunt?
Edit; apparently not all incarnations are bent.
I have a coil that is 1000 turns of probably 24Gauge magnet wire... I should be able to put my signal generator across that and stuff some wires in the end and use the air core... so a length of electrical cord with all conductors shorted as the short, and a resistor across another connection....
at certain frequencies I can get a opposed differential on both ends... I attached a scope 2 probes also one to each end, and shorted their common to the signal generator ground; but it was very low voltage...
I maybe need to find low voltage lights
Khwartz
Quote from: Khwartz on January 16, 2014, 09:37:26 AM
Hi all! Sorry for silence (well, I suppose few would say "don't be sorry, Khwartz, we were so very pleased you go else where a little time ;) ), but the spreading of the results and basic theory of Richard Vialle's autogénérateur need some agreement, organisation and time for translation.
I was about to find something really relevant to show you first and for me nothing is more relevant than a curve of COP well calculated with checking of all peers. So here are some praphics which should speak by themselves:
@ Pascuser. And all.
Dear Pascal, I very understand you no more wanted to hear about this Web site and its community because of the huge amont of time you should have spent in your try here to spread Richard's work and try to get some help here.
Nevertheless, I would like to support or work in France by posting here the current results and trying to answer the questions which would be asked here (even I am not a specialist of! You and others in the forum of Conspirovniscience are infinitly more about the Richard's Autogen), to encourage the study of the "RA" and try to get the breaking of the problems of the amplification and frequency generator consuption, and the problem of low output.
Above is the original post in the "Kapanadze daily free..." thread in OU.com I had made a call for help.
No, I am not bilangua and I am very slow to type cause often on a mobile and it is huge work to try this because I am always running out of time thanks to my professional obligations :/
I just will try my best but please be patient for any answer and new posts.  And of course, if the interest is maintained, any other help would be welcome to answer the questions (as I am not a specialist of the question myself I would rather prefer to focus only on spreading the French results and documents written by others than me, that I could try to translate).
Khwartz
Quote from: Khwartz on January 16, 2014, 10:26:42 AM
Here the link the the page of the discussion:
http://www.conspirovniscience.com/forum/index.php?showtopic=941&st=210&#entry31959
Here is the translation of one of the comments of Colas07 who made these measurements, largely confirmed by other experimenters and still rather closed to the predictions of Richard Vialle's theory:
Expert(e) [expert]
Groupe[group]: Membres[Members]
Messages[number of posts published]: 383
Membre n°[Member number]: 10156
Inscrit le[date of subscription]: 30/08/2012
I feed a 12V 5W light bulb
It consumnes 0.75W while the "U" [the "core" of Richard's autogen which has a U shape] only consumes 0.02W
COP = Pout / Pin = 0.7 / 0.02 = 35 but yes! A completly crazy thing!
I have done several times again the measurements in the same conditions and always the same!
I have taken my probe and a 50mA caliber multimeter at 330Khz directly on a light bulb and both give the same values....probe = OK!
I don't know why I am at 4.807Mhz and not at 3.6Mhz...it differs from Richard's predictions.
for the moment I don't see any error.... it is time to go on the next step.
Note from the translator: The theoretical power of a Richard's Autogen with a "U" of 1 m is 6 kW, which is in agreement with the several "burning circuits incidents" now registred while encounter this kind of power.
A call is made presently for help for reducing the consuption of the electronic stages.
Indeed, if we obtain even infinite COP in real while making the ratio output under input of the "U", as predicted by Richard's theory, we are hardly going up to 1.8 of COP, or just stay underunity, while making the ratio output of the U under input of the electronics which feeds the U. So we would much appreciate help from you guys if you are skill in these matter to reduce consumption in the electronic stage.
Cheers.
