0 Members and 823 Guests are viewing this topic.
NickZ
  Vasmus does have some videos out that show how he has his device set up. At least the basics of it, but no diagram of his driver circuits.
   I do like what looks like fairly simple circuit driver, though. If there is nothing else under the PCB.
NickZ
  I tried to use the current transformer (green 1" toroid with 40 turns of thick mag wire) to drive the Kacher circuit from the yoke. But it won't light even a small 12v bulb.  So, it doesn't have enough power to drive the Kacher driver circuit, as I have it set up now.
So, I may need to actually run two lines out from the grenade's output to another yoke core having a step down winding to 24v DC, to drive the 24v Kacher circuit with that.
  I'll install another green 3/4 inch toroid with 12 turns on one side, and 14 on the other side of it. This will go to the yoke center tap, and the other side to the Kacher circuit. We'll see how that works out...
T-1000
Quote from: NickZ on November 08, 2015, 11:22:40 AM
You will need +130-150V power line for the Tesla coil primary, the rest of circuit can be as usual. The current sense transformer should be used only for a drive signal and not for the power input.
NickZ
  Ok, well... I thought to try it to see what it would do. It wasn't much.  As I'm not using it for the drive signal, nor anything else, at this time. My Kacher is the older simpler type, as I'm just looking for the illusive "effect".  Which is not to be found, as yet, so I'm still looking for it.
   What would be more convincing is if Ursa, Geo, or anyone else, would show the self running effect, as well. Not just brighter bulbs, showing the resonant amplification effect, only. As it's been a few months now since those videos were uploaded, but with no self runners to be shown yet, as a follow up.
AlienGrey
Quote from: GeoFusion on November 05, 2015, 03:35:14 PM
Hi guyz ;)
Jeg, and others
these are some of Urfa's schemax.
look how the connections are hooked up.
try it, these Schematics I used and got some crazy results in effect.
Btw the Diodes act like capacitors! in a way I guess...
Below you also see a pic of the toroid he was using, yellow/green wire one was choke connection for pushpull and
magnet wire ~50-60turns enamel wire is Kacher connections, use the schematics to see how and what.
I do really think it's how you connect it in certain way is how you get the effect.
The Pushpull circuit is one which I also build, the Akula one some time ago, TL494 and IR2110 mosfet driver.
and regular Ruslan kacher setup in use.
If you want to see the Videos , Check mi Channel and see all 3 of them.
https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3FCw/videos
Cheerz
Hi in this device witch is a mix of Dally's original and  Ruslin / Akula circuits, I recently got interested in this unit but thought the nano pulsar a better option if it can be enticed into working. Now the oscillator works ok with a Texas 74hc00 as shown in the diagram, or does it ? driving the pulse with stretcher section wasn't to easy as the signal amplitude is attenuated some what and incapable of driving the 2T962A the KT device almost exhausted, unfortunately i would have tried the 74hc132 scmit trigger device in both places but i don't have any, i tried looking at the wave form on a 100mhz scope but it's not all that stable, i can see why every one has abandoned it's use, but I'm not sure this idea wouldn't work if done properly. by the way their are a good few HF pulse modulator devices out their on the TO3 surplus market but we are talking about 1 or 2 Nano sec devices. Any comments ?
