0 Members and 67 Guests are viewing this topic.
justawatt
Quote from: skywalker66 on March 15, 2016, 03:59:49 AM
After I eye ball several time at these videos I draw my own schematic. See attachment.
Look very smart design in simplification and efficiency assuming is not a hoax.
thank you skywalker66 for redrawing the circuit.
To add on to info ,we have seen 90% similar  circuit from akula0083 long time back .
justawatt
This is another video from Freeenergylt youtube channel.
Where some people is showing they can extract more power from kacker like circuit.
https://www.youtube.com/watch?v=9XelxZeEMDs
Where to drive the telsa primary we can use "GeoFusion; Don Smith partial replication Cloud version" circuit
https://www.youtube.com/watch?v=M-El9ObHCF0
skywalker66
Quote from: Dog-One on March 15, 2016, 11:33:36 AM
I commend your effort trying to decipher the circuit schematic of this device.
What I see has me cautious of its accuracy.  The main item that stands out is the circuit path of the load.  You will notice it traverses the secondary of the coil on the left which probably has relatively small conductor wire.  Hard to imagine 2000 watts passing through this wire without it immediately bursting into flames.
You meant it closed thru kacher secondary ? In deed, I worried about too. At the bottom of secondary kacher is current node, the maximum amplitude of current from entire secondary kacer. He may used a thicker magnet wire on his kacher like 0.8 - 1.2 mm, or just thicker for first part of kacher then follow by thin wire till bottom. I have a hunch he don't direct connect top of kacher to cooper pipe coil from the right side (on the "mixing coils") like it appear from video, but using a split cooper screen inside top of kacher. What you think about that ?
And his kacher it may be low frequency modulated.
I must admit, this device is closest replication of Kapanadze, and I tend to give it a chance of genuine. Nevertheless there remain some unknowns like blue cylinder, which I suspect is a hv home made capacitor, or a bank of capacitors inside. Therefore secondary coil from the kacher act like a current source (see 3turn secondary on yoke in ruslan-akula crt) for series resonant circuit consisting of blue cylinder (supposed to be a capacitor) and a induction coil on the left coil assembly. You see, blue coils assembly acts like grenade+ inductor+antenna  from Ruslan where high voltage with high current is mixed together.
skywalker66
Try don't see this crt as a classic one where the current is the same all over the place if there is not branches, where is safe to put ohm law at work. You know in Kacher secondary current is at max at bottom, and min at top, so no Ohm there...
justawatt
now compare the 200 watt device with Ruslan or Akula device.
I think the circuit diagram speak for itself
