0 Members and 432 Guests are viewing this topic.
Hoppy
I'm slowly mustering up the enthusiasm to launch into a new round of experimenting. I speculate that if there is anything genuine about Kapanadze's devices, then they operate with an output at grid frequency or thereabouts, as otherwise I cannot see why he would have approached investors with devices that were unable to power domestic / commercial appliances. I also do not feel that any elaborate electronics are involved. As Wottsup has pointed out, the green box push pull looks totally inadequate to power anything aproaching TK's lamp load. It may just power a step-up transformer for the spark gap, which appears to be just for eye candy on the 2015 device.
The Vasmus 'field' device video recently posted, interests me most with its intriguing low frequency pulser. The clamp meter reading on the earth wire of 1.2A - 1.5A suggests to me that this current may be flowing from the earth rod back to a hidden earth rod buried under the device (which is never moved or lifted) and is part of the pulser circuitry. I would be interested in anyones thoughts on this device.
Hoppy
Quote from: T-1000 on March 22, 2016, 02:55:43 PM
The grenade coils have to be oxygen free copper wire in all cases. The best source of it is the speaker wire which require high quality copper without additives for hifi speakers.
The time will tell what exactly is going on there.
Well, that would rule out Kapanadze's grenade coils being fit for purpose for NMR!
Void
Quote from: Tomtech29 on March 22, 2016, 03:45:11 PM
Discusses some scenarios for you wire and I remembered how someone conducted experienced speaker copper wire and magnet attracted to him?
whether this is due to low quality "more steel"
- and the copper wire or the magnetizes what is going on?
Hi Tomtech. Not sure what would be going on there.
It seems to me that both Akula and Ruslan used regular electrical wire, but
maybe they can get wire that looks similar to house-use electrical wire that is
oxygen free.
I would be interested to hear if anyone knows where this idea of using oxygen free copper
originated from. Where did Fabrice Andre and Ruslan get this idea from I wonder? Fabrice Andre was
attempting to replicate Kapanadze, so his ideas probably didn't come from Akula.
skywalker66
Quote from: T-1000 on March 22, 2016, 12:22:51 PM
Ruslan and also akula said is straight:
Attach 10 Ohm resistor to the grenade output coil and use inductor with generator attached to find current surge.
There will be spot when current will go "insane" and spike while there is not much voltage generated on the output.
Then step down input voltage and try again. Repeat until you are certain about specific resonant point. Then build generator to feed in same volage, frequency and duty cycle to the grenade.
Hello !
What current do you speak of? Where to search for such peak current ?
itsu
Quote from: Void on March 22, 2016, 02:14:04 PM
Thanks T-1000. Using a FET driving the inductor winding directly would seem to rule out the current peak being
due to the ferrite core then. Interesting. Are you seeing this current peak in your own tests T-1000? If so, around
which frequency? I will give this a try shortly...
Void,   be sure to use a big resistor, my 10 Ohm / 10W resistor started smoking in a few seconds.
The screenshot is from across this resistor  which was attached (only) to the grenade leads.
The push - pull was delivering 24V @ 4 A at this resonance (18.78KHz), so enough juice to fry this 10W resistor.
Itsu
