0 Members and 145 Guests are viewing this topic.
Tomtech29
Hi.
I was already anticipated in mind by"skywalker66"
- not what I have a different opinion if this system is the basis!
It is difficult to say how this transformer since no one duplicated ?
(if anyone of you is able to calculate the equation for power losses) a difficult task without knowing the inductance and quality factor of the coil.
from my observations, my guess is that: of drawing TP/ U1 (This nominal power) input, wherein winding 2 is 300T. 0.7mm2 + winding 4. 300T. 0.7mm2
designation U2 a secondary winding output 20T 1.5mm2 please write what is otherwise?
- winding on the ferrite rings 300T. will be quite confusing in the vertical position (without winders) :D
You could be done:
https://www.youtube.com/watch?v=nyMM3V9bbSQ
cleverly / hee.( some western )
"So how does this work ?? as soon as Trany switches on 'bang' dead transistor ! end of idea ? ;)
or i the key to it the feed back in the transformer ?"
and I think that this would somehow deal / with short pulses should not heat up thyristor or mosfet.
- why it is recommended as a thyristor? Hmm.
I thought that was interesting,causing the transformer that operates differently from the other ?
This will not affect the primary winding in theory it would make sense if it's true?
anyway reassured by the reliability of this device.
most logically without breaking the laws of physics
we have a high-voltage transformer: Kacher
then step down pulse transformer :D
and recovered energy stored and looped!
What can not be achieved by conventional transformers!
I know it sounds primitive
but it looks with that translation Ruslan.
guys like gambling?
small joke...
Tomtech29
Hi. Jeg
from what I'm hearing it
https://www.youtube.com/watch?v=d_IDicPswgw
output coil CW CCW 20 turns 1mm2 the output voltage of   bridge rectifier and a capacitor is 3.7 volts DC and 6 to 7 ampere!
He says inverter 220V plugged it received 14 Volt and 300 Watt? Max.
This is a little not close if it really is the output from the inverter?
3.7 V raises to 14V and the output of the inverter is 12V to 230V.
AlienGrey
Quote from: Void on March 30, 2016, 03:52:54 PM
Hi Nick. I suspect that the statement you made above is not accurate. You seem to be mixing
together two different things, and you are putting words into Tesla's mouth which I think
you will find if you care to look into it that Tesla never actually said at all. :)
There is no mention there of white corona discharges or aether at all. Tesla only seems to be talking about electrically charged
sound pressure waves of some sort. I will leave it at that Nick. :)
Your on about a Longdetutional wave like from a spark gap or a brush and slip ring assembly and a gap like in a universal motor com!
verpies
Comparing 14 year old MOSFETs with modern IGBTs is not commensurate.
I can cite modern MOSFETs that are 14x faster than modern IGBTs.
NickZ
  Verpies:
  Units of Aether?  Good question, if we could only see them, or measure them. But, we are not there yet.
  What are the units composed of in the common wind? Or better said,
what are the units making the wind force? Or driving the wind.
  What are the units of power in a vortex called.
   I can answer that, but for now,  What is vortexial motion called???  And how to calculate it?
