0 Members and 453 Guests are viewing this topic.
MenofFather
Quote from: T-1000 on March 31, 2016, 05:33:14 AM
This IGBT will be much slower with quite high 3700pf input capacitance and slow turn-off delay time of 190ns - https://www.fairchildsemi.com/datasheets/FG/FGA25N120ANTD.pdf
You will see it starting drawing current by itself between gate and emitter (drain) like IRFP460 when being run on 2-3MHz range which is required for smooth Tesla coil switching.
This was main reason why I swapped to higher frequency range operating MOSFET STF12N60M2 - http://www.st.com/web/en/resource/technical/document/datasheet/DM00187616.pdf and if you can find better one than this, it can be tested.
EDIT: The IGBT STGW40H120DF2 - http://www.st.com/web/catalog/sense_power/FM100/CL826/SC953/PF255269 might do a job and if someone can test with Tesla coil on 2-3MHz range, that would be great.
I mean not for Teslacoil. But for 15 kiloherc.
MenofFather
Quote from: verpies on March 31, 2016, 07:00:13 AM
IGBTs are slower than MOSFETs.
IGBTs have a higher i*v product at slow speeds, though.   ...but MOSFETs are more efficient above 100kHz.
Read this.
For voltage till 500 volts is beter mosfets. For higher voltage than 500 V beter IGBT. On Capasitors in Ruslan Video is 1000 volts. So need transistor on 1000 volts. So IGBT can be better. Less loses on input resistance (betwen colector and emiter). Frenquency also not hight - 15 kiloherc, For IGBT it is normal.
MenofFather
Quote from: Tomtech29 on March 31, 2016, 09:03:28 AM
Hi. Jeg
from what I'm hearing it
https://www.youtube.com/watch?v=d_IDicPswgw
output coil CW CCW 20 turns 1mm2 the output voltage of   bridge rectifier and a capacitor is 3.7 volts DC and 6 to 7 ampere!
He says inverter 220V plugged it received 14 Volt and 300 Watt? Max.
This is a little not close if it really is the output from the inverter?
3.7 V raises to 14V and the output of the inverter is 12V to 230V.
In that video Ruslan say not 3,7 volts, but 36 volts he get on output and 6-7 amperes. Then he put here inverter, who making voltage 220-240 volts, then he get 14 volts and can feed about up to 300 W with this divice.
NickZ
  How about just using a 1500v 15A transistor for that purpose, like I use.
   I had made a video a while back showing how I connected my Joule Ringer coil to the output of the grenade 168 turns coil, and then that was also connected back to the Kacher secondary. Which would light a CFL very brightly, but, since it was not able to work like the Kacher does and needs to be wired to the grenade or yoke core, I did not notice any improvement.
  But, the frequency of any Kacher circuit also needs to be adjustable. And unless you add or remove secondary coil turns, it won't be. Adding ferrite to the Kacher's pvc pipe does increase its draw from the source.
GeoFusion
Hi guyz :)
Void,
Yes about radiant energy.
That is Ambient Backround Energy which is everywhere on earth and in space.
Don Smith talks about this too. Tesla knew and talked about this Cosmic energy,
we  call it static electricity right? when exited for sure
Our Sun is of great responsibility of this source as other suns in space which are continuous.
Tesla coil infact excites it and pulls it towards the coil making the coil and topload work as a collector. open end cap.
:) be reminded by lightning, that is also radiant  ...between Earth and Ionosphere.
An example of a Spark Gap, Which creates shock waves and collapsing field will attract right?
ever felt a lightning strike close to you? You feel the static all around in your body and hairs.
I have an experiment on my channel using Flyback and sparkgap and could see how it behaves :).
Nick and all.
on the Aether Subject, that should be seen as matter of creation of everything within the universe, it's in everything.
Solid, Liquid, light, basically everything which will manifest. It will continue on a spiritual path of thought knowing
who creator is.
all in a different Frequencies manifestations and unique vibration geometry.
Tomtech,
This will refer to the diagram you posted earlier.
https://www.youtube.com/watch?v=4-flVbCreIM
We should try to build this too :). maybe I will give it a try.
Meno,
Hi  :) long time man.
Check these out if you missed.
1
https://www.youtube.com/watch?v=qEHKGSLy938
2
https://www.youtube.com/watch?v=7ELg1TclytM
Cheerz~
