0 Members and 236 Guests are viewing this topic.
MenofFather
One man write "
тех кто не скачал про дроссель Акулы . дроссель три ряда послойно,в слоях по 100 витков,труба 40 мм, провод 5 квадратов, конденсатор в пределах 50-60 нанофарад"[/color][/font]http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/129332-ustanovka-akuly-povtorenie.html?limit=18&start=54#129946
I do not know, from were he get this information, can translate. Drosel (in thirst videos, how I understand) is 3 layers, one layer have 100 turns. Pipe is 40 mm diameter. Cable is 5 mm2. Capasitor ia about 50-60 nanofarads.
Void
Quote from: NickZ on May 10, 2013, 03:45:38 PM
    So, are you saying that there is nothing to cold electricity, that it's all just due to a frequency difference and nothing else?
  We may not get the answers by comparing to what we already know, but to what we have not yet learn about.
   What SR 193 has mentioned is that it does not take a big powerful noisy spark to activate the coil to obtain the results shown.
  Lighting 1150 watts of incandescent bulbs like Akula does while showing a tiny or no spark, is not normal, or is it?
I don't have any opinion on cold electricity as people seem to use the term in different ways and I am not even sure what cold electricity is supposed to be. Well, if Akula's circuit is truly self-running then that is as not normal as you can get, and it wouldn't make a difference if he was even only lighting a flashlight bulb. Maybe Akula will come forward with more info on his devices in the future. I hope it is not just another hoax.
Void
Quote from: MenofFather on May 13, 2013, 03:03:38 AM
One man write "
Thanks for the info.
T-1000
Hi guys,
Just got proof of concept circuit diagram from tiger2007 for getting effect.
Akula's circuit is almost same just there is no piezzo element and there is suspicion for NMR going on yoke because yoke is getting hot. tiger2007 seen personally akula's device and he said, it is not fake but very unstable.
About piezzo element with plexiglass from http://peswiki.com/index.php/PowerPedia:Testatika :
"The horseshoe magnet contain four blocks of plexiglass-type media (p) alternated with copper (c) and aluminium (a) plates (in the series, c-p-a-c-p-a). It is unknown if these are perforated.  This phenomenon is related to variable capacitance generation and dielectric absorpsion. Two horseshoe magnets with metalised-perspex laminated blocks alternated with copper and aluminium plates form, what various sources call, "electron cascade generators". The electron cascade (or avalanche effect) is a chain reaction forming 'free electrons'. Insulated wire is also wound around the horseshoe magnets (which may also be in a bifilar configuration) for induction purposes. "
For sake of effect you might try understand this circuit and ask questions if something needs to be clarified:
NickZ
 @ T-1000:
   Thanks for the diagram, much appreciated. As that yoke device is about the only circuit that is, well,   known to work, for sure.   I hope...
  Can Tiger possibly be enticed to show his working circuit? It's been a while since the first prototype.
    I do have some questions, as the diagram's component values are not shown. Such as the coils size and windings turn count, transistor, cap, diode, and resistor values, etz...
   Nor do I know if,  this is a self-runner,  or not.
   A couple of pictures of that set up would also help. Or if a video is available, also.
  What the input/output specs are, if known, would also be good,   but, NO HURRY.
   I'll be studying what you've already sent.
                          NickZ
