0 Members and 123 Guests are viewing this topic.
a.king21
a.king21
forest
a.king21
The secret is not in capacitor, but in the way we can use it's discharge without damping it even with load. Follow the suppression to find the answer, the more suppression the closer to the truth.
You should mention some interesting facts about Kapanadze devices and comments. First: his aquarium device output do not fade when load is changed, second: he mentioned any frequency can be used, third: it taps external field.
Lenz law suppression ;-)
a.king21
Quote from: forest on May 23, 2016, 05:00:28 AM
a.king21
You have completely missed the point. Absolutely and completely missed the point
Jeg
Quote from: a.king21 on May 23, 2016, 04:25:47 AM
This is, I believe, the secret in plain sight.
https://www.youtube.com/watch?v=VY4Gu-ZUIBU
Hi A.King21
I believe the secret is not at plain sight at all. For me, the secret lays on the way D.S supplies his Tesla coil. As it is mentioned again, it is an other thing when we emit radio frequencies, and other thing when we emit dumping waves.
Thanks for the videos Geo, Grum, Tomtech
Geo
Even you do a nice job i still have doubts about your output power. I mean, if you consume 5A at 24V total about 120W, isn't it normal to full bright a 100W bulb? For sure you have a good ratio between input and output by the use of your HF katcer circuit, but still your system looks like below 100% efficiency. In addition, if you put an iron wire inside your Tesla coil tube, it will be heated the same...i guess. Thanks for sharing man. Keep your good work.
Grum.
Thanks for sharing your results. It looks like that the extended period of operation after you have disconnected your p.s, is due to your input high uF cap, in combination with the low transistor consumption due to the fact that there is no load attached to it. If you have other explanation, pls share it.  ;)
