0 Members and 75 Guests are viewing this topic.
AlienGrey
Quote from: conico on September 02, 2016, 10:18:26 AM
You can use LMC555 is able to osccilates  up to 2 Mhz maybe more, at 5volts
sorry is for this post:
''Guys i'd like to move to faster switching and i am looking for pwm controller and Mosfet driver able to run up to 2 or 3 MHz. Do you have any idea to experiment with? Any published circuits?  Thanks ;)
Hi at the expense of hurting someone's feelings what is the point of this circuit ? it won't run a bridge circuit as it's not symmetrical and the output/ input would be R/C temperature dependent and subsequently liable to drift resulting in one of the output devices overheating, you would have to divide by 2 on a leading or falling edge to correct it your then back to half speed the same with the pulse width idea as you then get variable dead time.
The same goes for the fluorescent lamp idea it draws loads of current, just get a 3 or 5 watt LED re wire the segments in parallel and use a cd4049 osc  2 nots and the rest of the nots in parallel to drive a npn pnp totem pole config and a voltage doubler with limiting resistor, it would use far less current and give loads of output light.
won't it work at a higher voltage and some of the IR devices already have the /2 in the chip like IR2153
Also are you forgetting all the coils would need we winding to accommodate the new frequency and ratio, would they not ?
no offence and good luck
Regards AG
NickZ
   I tried to connect my device the way that Geo has his. With the 3 turns induction circuit connected in series to the 168t grenade output coil.  I get no light at the bulbs, unless the Kacher is on, (just like Geo's device), but, I don't see any improvement as far as output goes.
   I don't have any caps or rectifiers on the grenade output coil, so it' not DC. If I connect by rectifier up to the grenade/inductor coils output, and back to the Kacher's input, the HV kills the induction circuits output. So, I may not have it connected up the right way.
  A simple hand drawn diagram from Geo showing the proper way to connect it all up, would help.
conico
Quote from: AlienGrey on September 02, 2016, 10:47:08 AM
Hi at the expense of hurting someone's feelings what is the point of this circuit ? it won't run a bridge circuit as it's not symmetrical and you would have to divide by 2 on a leading or falling edge to correct it your then back to half speed the same with the pulse width idea as you then get variable dead time.
Regards AG
It is symmetrical in first configuration if potentiometer is in the middle is 50 % duty cycle and you can change the frequency.
Look the diagram were the duty cyle is 50% you can not change it but you can change the frequency and duty cycle will be 50%.
AlienGrey
Quote from: NickZ on September 02, 2016, 10:48:58 AM
Hi can you please help us all out and load a pointer to the drawing ? and have you tried reversing the 3 turn winding and has the 3 T winding now changed to 4 ? or have i got that bit wrong.
regards AG
apecore
Quote from: AlienGrey on September 02, 2016, 11:03:19 AM
regards AG
Geo,
I am also intrested in your connexion details, i would also same as Nick verify the "effect" as you showed.
When three setups show simular effect we do have a reproducable setup and effect.
It will show also...if Nick and i get the effect....... that......the effect not is depending on a partically frequenty...there we all have different frequenty in our system.
If we not get the effect we know that we have to do more housework.
