0 Members and 331 Guests are viewing this topic.
NickZ
  Measurements, measurements, measurements:  I want, I need, I have to have measurements.
  Could be a fake, don't you know.
apecore
Quote from: NickZ on September 14, 2016, 12:11:47 PM
  A non self running device will always show a higher input than output measurement. Is that really of interest?
If so, please apecore show Hoppy your input to output readings, so that we can continue with more meaningful tests.
As I already know what you will be showing. NO OU.  So, does Hoppy.  So, what's the point?
  Economizing on the input, and maximizing the output may not work in this case. Try it and see.
   Hoppy: Please indicate HOW to measure a SELFRUNNER'S input to output measurements. So, that you can guide us all.
Or are you only interested in seeing measurement on devices that don't work.
Nick,
I will go a vew chapters back....so no showings for now.
As you say correct....first tuning to max perormance due i believe that my setup is not yet well enough configured.
apecore
Quote from: T-1000 on September 14, 2016, 04:52:20 AM
Here is akula's approach:
The instruments based on https://en.wikipedia.org/wiki/Electrometer are good start for finding Tesla coil frequency timings and relation between how much of charges are being attracted into grenade. For a start akula suggested to place small foil near the top of Tesla coil. Then connect foil to the few picofarads capacitor then to the ground for substitute of grenade. Then start looking on the scope for BEMF like kicks on the capacitor and maximising them right after Tesla is getting switched off is the crucial for finding what voltage and frequency is required for the Tesla coil. Only after finding frequency of the kicks and creating their resonant condition for the constant current flow the grenade coil is made as receiver for this exact condition.
This is what still waiting to be tested when I will get time in the lab.
Cheers!
Guys,
Lets get on track
As T-1000 explains the Akula approach...it also gives another look at our grenade....wich we all configure on 8Mhz...(37.5m)
As posted by T-1000....tesla coil gives by measurement the frequenty at the desired kicks to the grenade.
In one of the last sentences is mentioned that the grenade is made based on the outcome of the kacher.
As i read it.....i think that the wire length of the grenade is related to this kacher frequenty.
So the mystery lenght of 37.5m is only valid when the 2Mhz is generated by the kacher system.
This approach would lead more to the standing wave principles apearing in the grenade.
Gives this also answers to AG about the coil discussions?
justawatt
NickZ
  We have previously tried to follow Akula's method of finding the resonant frequency of the grenade coil, which did not give 8mhz, at least not on mine. And then trying to match the induction coil to produce the best sync between the two induction circuits. And after that further looking for the Kacher's frequency that will sync with the induction circuits, to give the best output at the bulbs.  However, this did not work for those that tried it, like Itsu.  You can look at his previous videos to see his results.
   The Kacher is matched to the grenade, not the other way around. The 37.5 meter coil, is the only thing that is not altered.
   Ruslan's method is different, and he did not follow what Akula did, nor use the same circuits. Yet, has achieve a much higher output. And has explain and shown every device, up to now.  Akula did not, he hid the circuits inside the boxes. Which is why we started going with the Ruslan way, instead. Plus he has provided schematic, diagrams, and videos, of each self runner. Akula did not.
   I've have given my suggestion for you to try, in one of my last posts, of what connections are working best for me, so far.
Geo has also explain about his way of doing it, as well.
   If you think that the Kacher should run at 2Mhz, then shorten your Kacher's secondary and test it for yourself.  While keeping in mind that none of the self runners shown to date, are using a 2mhz frequency to sync with the induction circuits, or grenade.
Each self runner shown is running at different frequencies.  Compare them for yourself, and see. There is no single magic frequency to tune for.
