0 Members and 151 Guests are viewing this topic.
stivep
Quote from: forest on October 03, 2016, 02:41:49 AM
The electron is the source of energy or rather is the valve ;-)
The answer is: none of it.
Can  some of you memorize few sentences below?
I pointed  delta T in my past two posts.
And it was somehow  not noticed by you. :)
1.Without  potential varying in time  frame there is NO WORK done.
2.static potential  is just a bite  to  attract electron flow, -It is there, and there-is no work performed yet in its static form.
3.magnetic field  of a magnet  is self contained system,  incapable to do  to do any work at all.
( delta T is missing)
4 So far there is NO  prove that anyone was able to exchange energy-(
that  means couple to),  with  magnetic field of  a magnet.
magnet is just ignorant body  manifesting its presence, you can kick around it  like you kick and jump around rock. You can not disturb it by that.
the only difference is that magnets boundaries of its magnetic field  are not immediately visible
to an eye.
Summary:
electron flow from  ground wire to  the Tariel Kapanadze  device is thought to be  a result  of presence of:
- firstly created Electrostatic Potential, between the ground and the device.   That  EP than must be present all the time  the electron flow  is  required.
   However EP character: is time varying dependency, and its character  is based   on tuned   factors of Delta T.
   of nano or picosecond  generator of impulses.
hint:
Tariel Kapanadze when I spoke to him in Tbilisi wanted to avoid talking about the device and especially about nature of impulses.
He was  very primitive in his impulse generator at this time.
Tariel utilized spark gap , where energy of very quiet spark was small and  very much uniform.
The frequency of spark  have not been very high.
However interesting was that interval between impulses was longer than  delta T of the length of each individual impulse
Look at his videos with the green box
In the device he presented to me he used  impulses of HV coming directly from  gas heat  furnace  that was giving burst of impulses
every time it was  triggered.
so if the wires  from power  have been connected such a way that triggering wire was constantly  trigger ready for nest burst than that burst was repeated over and over again.
There you go.
Tariel Kapanadze device was not very much requiring in stability nor its accuracy or quality impulses.
He killed three problems at the same time.
1. no need to build any nano/pico second generator (it was likely  millisecond generator.)
2. no need to use any  transistors to convert it to HV ( High Voltage)
3. no need to create initial EP ( the impulses have been already at high voltage potential
so the reminding  question is what triggered trigger wire of that High Voltage block( electronic board)?????
Isotope?
QuoteWesley-
In the very simple language that character of EP is:
1-
static, (only at very beginning)
changing to--------
2-
dynamic, (based on picosecond   impulse from say picosecond generator)( delta T is present)
changing to--------
3
-static ( during dead time interval between impulses, -and this is the time of electron inertia)
4. energy to the nano or picosecond generator comes from ??? ??? ??? ???
If you do not read my 3 posts you will not know. :)
If we  picture it:
than, that picosecond impulse has nanosecond  intervals and is square in shape  and
we must remember that Square signal  has
  1.rise time AC
  2 top of the impulse DC
  3. falling edge AC
  4. the interval between impulses is DEAD time- nothing is there and that is  your  delta T of dead time.
  4a.only in this dead time  inertial mass of electron  can  be noticed.
  That inertia  is your  temporary energy storage similar to  flyback effect or fly wheel effect.
If you want  this energy to be stored for longer time, than please :
   1.  add resonance circuit,  LC
   2.  tune it to resonance of flow or push that flow with nano or picosecond impulse frequency to work for you  with  maximum efficiency.
So where is in here any presence of any particle decay isotope? ??? ??? ??? ??? ??? ??? ??? ???
That presence  of that small nuclear energy converted to electricity
Well  that isotope is your "system life support"
think of  already accumulated energy  in the flywheel, that needs very small sustaining energy coming from outside  of the system to compensate the losses,
Knowing that we are dealing with steady parameters of the load.
https://en.wikipedia.org/wiki/Flywheel
If you want your TK device to work, than  you must TAKE TO CONSIDERATION THIS POST.( take my last 3 posts and try to understand it "word to word" most likely everything you need is there)
I'm just different  individual from 9/11
-after  September 11 when I was lucky to do not die
-and after Russians poisoned me and I did not die.
-and after Venezuelans visited me ugly  way and without invitation.
I do not need or want any fame, I do not need to build the device.***
You guys put your heads  in danger if you build it and  try to cash it, so if  you are  simple smart M...r F....r than   face the consequences
I just give you  help in it.
I do not care about business or gain any longer. I have enough of friends money hungry in case I would need financial support in my research.
..Most of you are just opportunists.
Wesley
*** that statement is true, even if the device was already build , :) or know  who build it :) , or or know of the fact, that I really know how it works :)
The only question remaining  at this point is : Do I know ?
Enjoykin2017
Quote from: stivep on October 01, 2016, 11:37:50 PM
the answer is simple
Overunity in physics does not exists!!!
Overunity in economy of facts  exists only as  economical gain.
I suggest  at minimum to watch this video at its current time or view it from the very beginning.
https://youtu.be/8Hf3SKcn4OI?t=246
Our "overunity " comes from initial investment in energy that comes from our pocket  and that allows us to couple to  energy source that we do not have pay for
Wesley
PS:  DO WE HAVE HERE ANYONE WHO IS FROM SERBIA?
I think you are wrong StiveP -very wrong !!
You want a proof for pure OU system. It is closer to you ever imagine.
Take your HEART . It is PURE OVER UNITY that nobody CAN NOT DENY !! MORE POWER OUT THAN IN !! TYPICAL CLEAN OU SYSTEM. !!
Wesley take yourself a favour - dont listen Main Stream Science Liers !! And dont spread that there.
Answer on PS : YES HAPPILY HAVE - THE ONLY ONE SERB AND I THINK GREATEST SERB EVER. WE ARE READING HIS PATENTS AND USING HIS AC ELECTRICAL SYSTEM AND MUCH MORE FROM HIM WE USE !! HIS NAME IS NIKOLA TESLA !! HE- HE- HE- HE !!  :D
Have a nice day.
Enjoykin
Enjoykin2017
Ok people  -now back to technical aspects
Very interesting schematic came from Realstrannik member DELAMORTO
His variant is below. Shortly - accelerating "soft" electrons from inverter with "hard" electons from HV AC transformer (not fly back because FBack has several HV-diodes at secondary side and DC output). We need HV AC output.
Very interesting schematic that pushed me to start reading again very interesting book abut "soft and hard electrons" and masking hard electrons by soft electrons.
The book name is Cater, Joseph - The Awesome Life Force -
Take a look at this schematic and try to study it. Special interest belong to cylindrical  cylindrical asymmetric HV capacitor and steady HV E-field in it. Take a thought.
Reg.
Enjoykin
Enjoykin2017
RED ALER WARNING !!
Teslas lecture "ON THE DISSIPATION OF THE ELECTRICAL ENERGY OF THE HERTZ RESONATOR" IS NOT THE SAME AS LECTURE I WAS EXTENSIVELY SEARCHING "THE DISSIPATION OF ELECTRICITY" WHICH IS 1000% POSSIBLE HIDDEN VALUE IN SOME AMERICAN-CIA-NSA-PENTAGON VAULT DEEP UNDERGROUND !!
"THE DISSIPATION OF ELECTRICITY" LECTURE IS IMPOSSIBLE FINDING AT INTERNET !! FOR ME THIS SAYING EVERYTHING !!
Reg.
Enjoykin
stivep
Quote from: Enjoykin2017 on October 03, 2016, 01:36:27 PM
Have a nice day.
Enjoykin
I accept the fact that you have your own opinion.
1.can you support it  with any facts?
2.can you  explain to us what you meant by term:open system?
3. can you explain  to us what that overunity  of yours comes from?
With all due respect be a man have balls .make and store the reproductive effect on our society.
Take stand.
Do not kick us with your believes.
Wesley
