0 Members and 100 Guests are viewing this topic.
apecore
Quote from: lost_bro on December 18, 2016, 10:02:17 PM
Good day All:
In relation to this video:  https://www.youtube.com/watch?v=ZTOrWiQ1rJ4
1_My guess is that this is the DIODE that runs to *ground* from the base of the secondary (Karcher).
Second;  Please note the couplings that Ruslan used on ALL the connections to his coils
take care, peace
lost_bro
Good day Lost_bro,
I do believe your not far from truth ;D
To get it more specific..
1_ The position of that diode is pointing that direction....other possibillity could be that it is a fet wich switches the kacher transistor on and of?
But in that case there must be something to synchronise the switching.
But in my opinion for good stable synchronising there is a need for electronics,...due this maybe will not be possible by using pasive components?
Can we asume this?
And next...when it us a diode and connected as Lost_bro posted, would it illiminate the negative period?
2_ statement seems to me logical,...therefore i like to know wich type of connectors are suitable for the job?
Greetings
Jeg
Quote from: boonk on December 19, 2016, 06:08:21 AM
Hi,
Yesterday, I give  on one Russian forum
- They spat at me!..  :D
Hi Boonk ;)
Have you tested the circuit? In what frequency Cr is tuned to?
Do you have more info about the stepping down transformer? Primary turns, secondary turns etc?
Thanks.
@Lost_bro, Verpies.
I moved to 15V gate voltage, while decreasing to 2 Ohm the resistance after my tc4420 driver. Things changed dramatically. No parasitic oscillations, clean on/off transitions, higher frequency ranges. Thanks guys :)
NickZ
  apecore:
   Could it be that Ruslan is using two transistors, instead of just one, to help share the load, in order to lower the heat to each one. As these 2sc5200 can get really hot.
   I don't think that particular diode would work well without heating, if it's connected to the base of the transistor(s).
   Jeg:  Have you been able to see any interaction between your Kacher and the induction circuit?
   How about posting a new picture when you can. It's good to see you working on all of this, again. As there is only a few of us actually doing something other than making more and more comments, trying to redesign the wheel. As if just trying to replicate a working system is not good enough. Or even trying to replicate a working version that has no schematic.
lost_bro
Quote from: NickZ on December 19, 2016, 09:01:54 AM
  apecore:
Good day NickZ
Actually I do not consider that *searching* for the M.O. of a phenomenon is trying to redesign the wheel.
My bad, I thought this forum was here to *rationally* discuss precisely that: new and unexplained phenomenon..............
I do not claim to know how this device functions......... I am only thinking out loud so to speak.
If we already knew how this wheel *spins*, I would not be here to discuss it with you. I would just Google it, get the M.O. and then go to the bench and get to it.
I do have plans to replicate this device, but I do not blindly throw together wires and other such odd parts only to hope that I will *hit the jackpot* and then have a fully functional device.  My time is far too valuable.
Before I start any project I generally like to know *what* it is that I am suppose to achieve with that build and *how* I am to achieve it.  I always design and simulate before going to the bench, sorry if that seems old fashion to anyone.
Quote from: apecore on December 17, 2016, 11:39:09 AM
............. discussion in which we reached some theoretical breakthrough.
Which makes it all engineerable
So in order to continue that research;
Quote from: lost_bro on December 16, 2016, 01:19:20 AM
Don't know if that counts, unless the HV pulse could travel back to the Yoke core/coil windings through the Grenade windings.
Indeed it could.
Conico,..  and also i have noticed that push_pull frequenties gets different by activating the kacher,.... (without gate spiking)
Thus also this means as Lost_bro pointed out that the frequenty matching of inductor/series Cap/ 3 turns coil is critical and maybe the final goal to get the EMF from the kacher continously at the same moment/ position in the induced grenade wave?
ps,...  i don't have a cat,...  my girlfriend has one and he doesn't like HV 8)
Greetings
I firmly agree with Apecore,:
I really don't care how exotic this device may appear to be, if it is genuine (and I do not believe we all would be here if we thought otherwise), then the operating principle can and will be explained and the engineering behind this phenomenon will be disclosed.
I am sorry to have to disagree with you on this one, but I cannot believe for one moment that Akula, Ruslan or anyone else with an operational device, just haphazardly, counting on Lady Luck assembled a device capable of *free running* without the need of understanding the underlying principles of operation or without need of doing any calculations.
I also believe that *some* of the important design parameters have been purposely withheld from the public.  And I am sure that even with expertise of an RF engineer with associated test gear and ALL the design parameters, the assembly of this device is far from simple and quick and WILL require various calculations and planning.
Good Luck!
take care, peace
lost_bro
Hoppy
Well said lost_bro. I totally agree. I too do not have the time to just play around endlessly with the claimed self-runnier circuits so far shown, with no understanding on the principle of operation, in the hope that a Eureka event might happen by luck. I am happy to now just monitor the forums (with minimal comments about fakes  ;D ), hoping I get some inspiration and motivation to experiment further from ideas being discussed. Its important that all avenues are explored through discussion.
