0 Members and 78 Guests are viewing this topic.
GeoFusion
Hi :)
A sneak peak of my 2nd build of Ruslan's Setup
Grenade is 37.5m. Kacher is experimental length with tapping points.
By connecting by each tap will give another frequency and shortens length where
To find best resonating point with Grenade.
~ 1.1 Mhz was one of best results up till now that includes with antenna on grenade lighting 25W mircowave bulb,
kacher 2nd without antenna it will be 2.5Mhz +
These 2 recordings will give pointers.
Next ones will be with scope session a long one.
Kacher tuning and more
Here I am able to set Different Frequency ranges for kacher in a simple form.
watch the excitement coming :)
https://www.youtube.com/watch?v=S1CtAX-KVWI&t
Sneak peak of complete operation
Took me a while to tune it right but here it goes
https://www.youtube.com/watch?v=B9t8UptLZXw
Pls be careful while experimenting with Long streamers of Ions.
They of high power and high accelerated rate will scorch a hole  on body part like a lazer shot.
not to forget the output....
be careful, can't stress to much on this.
much more to come
Cheerz~
Jeg
Quote from: Tomtech29 on December 27, 2016, 10:39:56 AM
....I was wondering what are taps on the primary coil Tesla affect modulations
So sometimes I think myself that it can be and so in the case of Ruslan device .:D
https://www.youtube.com/watch?v=kdwVR-DnF-I
Hi Tomtech
Can you describe with a few words how does he modulate his output? I speak about the attached video. Thanks
Hi Geo!
What a nice toroid instead of yoke! What is its type? Congrats for your new setup. May be the final one! ;)
conico
Hi geo,
I have not seen ground wire in the second movie, Did you used a ground wire?
GeoFusion
Quote from: conico on December 28, 2016, 11:06:50 AM
Hi geo,
Hi Conico,
Yes I did, Same side connected in first video where you see how I was tuning kacher.
If you look closely in the second video, you can see the wire running along side the bench.
black wire. ;)
Without the ground , it's basically just dead or bearly any power to power the load.
Edit: *
Connected at first layer side of grenade.
Hoppy
Geo,
Do you have the mains earth wire disconnected from your PSU? If not, what is the effect on the lamp when you disconnect it?
