0 Members and 73 Guests are viewing this topic.
Grumage
Quote from: GeoFusion on December 29, 2016, 08:39:23 AM
I think Carbon Fiber tubes like that will be the best to handle this situation if it becomes hot inside.
Dear GeoFusion.
Hmmm.... Perhaps not !
Carbon is electrically conductive it would severely reduce the coils " Q " factor.
Kind regards, Graham.
conico
I think Geo refer to   cardboard not carbon  fibre !!!
Hoppy
Quote from: GeoFusion on December 29, 2016, 08:35:11 AM
Hoppy,
I managed to do the test, No difference observed.
All sorts of heights tested.
Even placed it on the part flat roof of my house and still operating.
Today will be trying it out with the Akula version Kacher which i have shown in vid.
It will be sharing the signals of Push-pull driver on the outputs of IR2110.
Lets see how this one works :) .
Thanks for trying that Geo. It would make no difference with a mains connected PSU or UPS but should with just a battery powering the device. However, the battery cannot be lifted and held at various heights in hands and would need to be raised and supported on dry wood blocks or cardboard boxes. Your roof would also not be a suitable support as its footprint to ground is huge. The object of this exercise is to look into the possibility of capacitance from ground to battery providing a return path for HV / HF current, not as you appreciate, a practical method for tuning. If absolutely no difference was seen to the waveform when scoping (mains isolated) across the lamp, then this IMO would be a significant observation.
lost_bro
Quote from: conico on December 29, 2016, 09:36:48 AM
Hi, AG
You can stick cardboard on PVC pipe but beware that it will increase the thickness of  the pipe and you will change the parameter of the coil.
You can glue paper or cardboard or prespaper on PVC pipe for secondary Tesla and Grenade coil, will have a high frequency .
You can use this calculator:
http://gorchilin.com/calculator/reactor?l=40&d=1.5&D=50&L=0.25&G=1&C=0&E=1&dt=0
I had a surprise in my case , the wire was 2.4 mm Sq not 2,5 and the PVC pipe was 1,6 mm thickness not 2mm like Ruslan device.
  the most important is if you use the calculator is that two lines on the graph to meet.
  so, measure copper wire without insulation and with isolation, measure PVC tube thickness, use the computer and see if it is closer to reality
This is the graph of my coil:
Good day Conico
Damn fine job............ this is the resonance *within* resonance or -double resonance- which many have spoken of........
Question:  How did you relate the Total length(802mm) given in the Calculator results  (single layer solenoid - one direction winding) and apply it to the Grenade coil (multi-layer solenoid- with reverse windings)?
I will attach this US patent ............. again................
This patent pretty much sums-up whats really going on here.........just imagine a multilayer solenoid in place of the Flat reactor coils in the patent.
take care, peace
lost_bro
AlienGrey
Hi AG,
My first grenade was wound on normal water PVC 50mm diameter.
the PVC at the very end where there the wires come out became brittle because of heat some time ago.
but still good.
New Grenade is of same diameter but of a much better heat resistant PVC.
Thanks for the information both Geo and Conico  :D ;)
Any one seen this ?
We need one in Russian!
