0 Members and 60 Guests are viewing this topic.
AlienGrey
I think I might have some thing here a caducious coil, wound with a 3rd input winding of 6 to 8 winds of 18guage it gives 2 outputs out of phase with strange currents in each wind it also has a collection of ferrite internal rings about 20 of them base 8 hex 403250, you would have to build your own and plug and play. Any way I'm starting to lose interest  8) 8)
NickZ
Quote from: Hoppy on March 02, 2018, 03:35:18 AM
Hi Alien,
Yep bit taters here! Emma has poked the beast right up the arse!! A couple of those in series should fit the bill.
  A bit taters, huh...  Nice and warm here, though.
  I'm going to change some of the caps on the input on the yoke center tap. To see if that makes any difference. I'm more worried about the up and down blinking of the bulbs, when the feed back circuit is on. And it also limits the tuning of the TL board to just one spot on the TL frequency controller pot. Otherwise the feed back PS does not power up, from lack of input to it. It only power up if it gets the proper amount of juice to it. Which only happens when the device is in it's best resonant mode.
And NO Where else. At least on my unit.
   Also I think that some bigger uf caps are needed at the input that will store some of the energy when the device is turned off. With a switch at that point so they won't drain, and will retain the charge to jump start the device, without a battery. Although using a battery to jump start the device, is probably cheaper than buying expensive high uf caps.
  Ruslan is able to start his last devices with just a small 9v battery. So, it doesn't take that much to start the device, when everything is working right.
Hoppy
Quote from: NickZ on March 02, 2018, 09:33:15 AM
You could start your device with a 9V battery if you had a latching circuit like used by Ruslan. ;)
NickZ
   What do you mean by a "latching circuit"? Used where?
Stalker uses 4700uf cap at the yoke input. And a 2uf cap
  I've replaced the input caps to the yoke center tap.  Will test the results now.
apecore
Quote from: Hoppy on March 02, 2018, 11:19:17 AM
I m almost there....  little bit more efficiency to improve..
