0 Members and 575 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on December 02, 2018, 11:17:28 AM
Hoppy no they don't but I have had some very large pot cores for very little of them and copper wire I wound one for 800volts and feed it into a multiplier of diodes and a few caps you only need low impedance simple do you want the part numbers for the core bobbin and clips ?
Thanks but I've got a few of them and a large LOPT, so may try setting up a firework display with them. Need to know more about the construction of the ion wind thingy.
AlienGrey
Quote from: Hoppy on December 02, 2018, 11:29:15 AM
he used 30mm copper rings with a pin in the middle, you will  need a few 1000v fast diodes in a string a 0.1 cap at 20 kV will be expensive
RS doesn't do many high voltage caps now. It ramps up and then arks across dead fast like a fly back.
I'm not sure you need that much voltage could use glass bottles silver paper on the outside and salt water in the bottle like Tesla used to get it going I use to do some work on the tilting train in the 80s they used them on it I wonder what happened to that thing.
magpwr
Quote from: AlienGrey on December 02, 2018, 01:42:55 PM
Hi AlienGrey,
No offends.But were you distracted by this experiment only because someone says that "his capacitor exploded". ::)
The capacitor exploded because the person did carry out the experiment but failed to know the flyback produce around 37kv which far exceed the capacitor voltage spec 20kv...25kv. :)
The  experiment with flyback which I have carried out with best energy transfer through 3 spark gaps(Around 1kv rated each) using just 1 x 2.2nf 50kv fat blue ceramic capacitor.Bought from ebay China seller.
https://www.youtube.com/watch?v=VQb6oyRXMrY
But i what i am curious is after the spark gap then connect to L/C coil.I was more keen to know what kind of waveform would i get and the amplitude . But this is planned for other time.
AlienGrey
Quote from: magpwr on December 02, 2018, 06:29:53 PM
Hi AlienGrey,
But i what i am curious is after the spark gap then connects to L/C coil.I was more keen to know what kind of waveform would i get and the amplitude. But this is planned for other time.
HI there I'm not sure the capacitor blew up but the spark gap sort of gives it away. I'm more interested believe it or not on the waveform your device produces my guess it's a ramp and a narrow flyback pulse, Tinman did a similar experiment where the shared energy is reflected back into the other coil as an amplification. I did chat with Ansis but he is reluctant to film or reproduce the experiment, such is life but that all part of life. Anyway thanks for sharing.
Hoppy
Ansis description in Wesley's original post on his thread comments: "Note! When effect comes, 300 Ohm resistor will start burn out! Voltage on battery will start go up. I just play with Ionization..." Clearly, the zener went s/c for the resistor to burn and battery terminal voltage to rise.
Are we to consider it feasible that Kapanadze used this principle to boost / condition a hidden high capacity battery (the trick?) such that it could power an inverter for long enough to maintain the lamp load for the durations shown in his various demos??
Hi Magpwr,
Could you please sketch out and post the circuit diagram used in the video link you posted?
