0 Members and 83 Guests are viewing this topic.
color
It is important that the voltage is more appropriate than the resonance itself. This is due to the principle of operation, which is not mentioned here.
Please understand that my English is poor.
You talk about high voltage,
In fact, the high voltage is not required by tesla kacher et al.
220V is not required either.
https://www.youtube.com/watch?v=d_IDicPswgw
It goes up to 1063V ~ 963V.
Why?
You have to figure out why the voltage measured at the lamp is high.
And you have to understand the half wave.
Half waves are the real reason to make additional energy.
So where does the half wave come from?
Where should I connect the half wave?
This is the principle that the generator works without having to increase the pressure anywhere else besides Tesla kacher.
https://www.youtube.com/watch?v=zgEecYI5ZQU
Ruslan promised to demonstrate with a Yoke transformer,
Change your mind and turn it into a small transformer.
Perhaps you did not want your simple generator to work.
It seems complicated, but it is simple to understand the principles.
Show me your video.
You need to know your progress so you can give the rest of the advice.
As I said, it is difficult to advise unless you experiment.
My friends also need a circuit diagram.
So I demand to make it from the generator.
It is faster to create and understand.
color
hi color,
Base on interesting diagram you provided i extracted this information as attached which is just part of Tariel device.
You do not understand the Tariel device.
No spark gap is required.
The reason is,
https://www.youtube.com/watch?v=r99g4mjEvTE
Sparks occur in the 17th minute,
The second time the spark disappears.
Why?
https://en.wikipedia.org/wiki/Townsend_discharge
This is not how it works like Townsend.
kapanadze or Ruslan generators also use lightning charge imbalance.
So you do not need two grounds.
One ground is enough.
You understand the principle of lightning.
https://www.youtube.com/watch?v=atALbOXRnE4
magpwr
Quote from: color on January 24, 2019, 09:01:11 AM
hi color,
The reason is,
Why?
hi color,
You are indeed observant related to Tariel.Thanks for that.
There is only "one" Earth in my hand drawn diagram.All are link to the same Earth by one wire.
I do noticed there was "no spark at spark gap" after the 17minutes video but yet the bulb was able to stay lit.You are right on this part.
But the spark gap still needs to be there as shown in my hand drawn diagram.Spark gap is a requirement in diagram may or may not be activated...
There was someone whom mentioned that Kapanadze coil needs  to produce ions.But this possibility can only happen if it is powered by A/C 220volts inverter.
------------------------The candle flame video will work with high voltage "DC" only since  2 plates hold positive and negative charge.This ions to flame control is a hint that High voltage A/C do not work the same way.Unless in a given point of time "ions" is produced from positive or/and negative phase and shortest possible time for kapanadze coil.
Belfior
Quote from: color on January 23, 2019, 05:39:28 PM
Wesley thanks for that long reply on Dollard as he has been elevated to a demi-god, and the operative word is his mathematical understanding of Maxwell.  As you have pointed out that the "experts in their field" are many times  wrong and their character has allot to do with their mind set, there are many forms of mental illness and as levels such as being homeless with despair.. I tend to look to at history as foundation of past constructs where advancement and failure has to be balanced by objective of the persons past life of learning...
Keep on as time stands for no one..
You might want to understand Schrodinger's wave mechanics rather than the Maxwell equations.
https://en.wikipedia.org/wiki/Schr%C3%B6dinger_equation
I wonder if AlienGrey's cat in China is a white cat or a black cat,
The poison gas that determines whether the cats in the Schrodinger box are dead or alive is, as far as I know, the poison of the Apepi(Abba, Abaddon or Apollyon).
The view of the Apostle John is well known.
Of course, it is better to understand electricity than poison.
Interference is everywhere.
https://3.bp.blogspot.com/-3W8V0RtMjW0/XElBGA4a2uI/AAAAAAAAA2o/VaK0F9w6A6kGPIjOioRDdcN1ZD3PdSNyACKgBGAs/s1600/QuantumHarmonicOscillatorAnimation.gif
It is not special.
Many people in my country know what I know.
I also think that Dollard has a lot to give, but he also has his own demons and misconceptions. When those are added to a big ego, you never do proper research again. All the evidence starts to point into your opinion.
Got all books that Steinmetz wrote, but there is nothing I can find that was written by Ernst Alexandersson. According to Dollard Ernst invented radio that was different from Tesla and Marconi. Marconi's radio is what we use. Tesla's version was longitudinal. No loss in energy or speed. Alexandersson's version was energy disappearing at point A and appearing in point B.
Also I think we need to go as far as we can to get any useful information from books. Pyramid walls are a good place to start
color
https://www.youtube.com/watch?v=hIfX97blwzY
Many people believe that the kapanadze generator works like the above video.
The reason is that there is a spark gap.
When the 5KW light is on, the spark gap arc disappears.
Why did kapanadze create a spark gap?
The Spark Gap made us aware that Tesla is working
It is a kind of high voltage discharge device.
When an output occurs, all force is used to turn on the light
With the lights turned off, Tesla's force is moving and looking for a place to discharge.
This is what makes it mislead as a spark gap.
Tesla simply acts as a pump to pull out positive ions from the ground.
It is not a spark gap, but a different way.
In a way that you know very well ...
You are not acquainted with this principle because you are not accustomed to it.
When you understand, laughter comes out.
